Prusa mini - PSU power cable hole
victor67y
(@victor67y)
Utenti
I really like the Prusa mini enclosure.  😀
It is a strong material and the whole printer, spool and PSU can fit inside. With the WIFI module; only the PSU cable goes to the enclosure
However; it is a bit of a loss that the PSU cable does not fit into the original hole in the bottom. So a quick hack using a multi tool (Dremel). I made a sort of square of 3 cm by about 1.7 cm.
Might be an idea for Prusa to add the PSU cable cut-out to the bottom plate. 😉
BTW, first post, not sure if I am following the correct rules 😇
Questa discussione è stata modificata 2 years fa da victor67y
Postato : 20/07/2024 10:05 am
domble
(@domble)
RE: Prusa mini - PSU power cable hole
I was happy to leave the PSU on the outside. The mk4 enclosure specifically removes the PSU from the printer (it's usually attached and part of the printer frame) and places it on the outside of the box. The mini enclosure seems to me to warm up inside faster than the mk4 does (less volume of air to heat?)
Interestingly the mini enclosure 3d model files on printables includes an external PSU mounting frame.
No mention that I noticed in the build instructions about main PSU position or wiring though. (Just about the supplementary supply for led and filter fan, which I didn't have).
Postato : 26/07/2024 8:36 pm
