Dry Box feeding, how I did it.
TheLivingBubba
(@thelivingbubba)
I live in a high humidity area so I generally print PETG from a Sunlu S2 filament dryer, just wanted to share how I did it to help others.
I had been using this magnetic reverse bowden before I had the enclosure so I reused it. I've read about loading complaints with the enclosure included parts so I just reused this. https://www.printables.com/model/108656-magnetic-reverse-bowden-adapter-mk3s
Sunlu wedge bowden feed https://www.printables.com/model/219366-sunlu-filadryer-s2-improvement-wedge
I used this pass through for the PFTE tube from the dryer to the extruder. I didn't bother to design a wider opening, I drilled it out with a 3/16" drill bit and pushed the tube through.
https://www.printables.com/model/276463-original-prusa-enclosure-filament-passthrough
This setup allows me to feet from the dry box, if I print PLA I plan to use the inside spool and included bowden. When I want to do that I just take the top magnetic bowden part and put it on the Prusa enclosure bowden tube.
   Hope this helps someone.
Napsal : 08/10/2022 2:15 pm
1 lidem se líbí
RE: Dry Box feeding, how I did it.
Thanks for sharing.  I might do a similar design for the other filament dryers I own.  Thanks for sharing.
Napsal : 10/10/2022 11:26 pm
Jonathan
(@jonathan-8)
My printer has the same dual light bars as yours. Thanks for posting photos of it inside the enclosure. I'd been wondering it it fits!
Napsal : 12/12/2022 5:14 pm
Zappes
(@zappes)
I want to do something similar, but somehow I don't like the idea of having to swap the bowdens. Has anybody ever tried achieving something similar using some kind of a Y splitter right before the extruder?
My models on Printables
Napsal : 10/10/2023 2:08 pm
