Z offset function since 2.4
Ruebarb
(@ruebarb)
I'm not sure if I am the only one, but my z offset no longer works since 2.4x, working previously on 2.3X. No matter what value I enter, it does nothing. I used to able to adjust for different plates for each of my printer profiles a created, one for smooth and one for texture, then I had one for pla &, petg, tpu, ect...  I created different physical printers, and used the one for the combo I was printing. Since 2.4x, the value entered in the z offset does nothing at all.  Am I the only one?
Thanks
Core One L MMU3, MK3S
Postato : 17/04/2022 10:09 pm
What printer are you using?
It would be better to adjust your Z endstop - on Prusa printers this is mostly dealt with in the printer firmware rather than the slicer.  I doubt many here have ever used the setting. I no longer use a printer that needs it so yes, you may be the only one.
Raise it on Prusa's Github.
Postato : 18/04/2022 1:01 pm
Ruebarb
(@ruebarb)
RE: Z offset function since 2.4
I'm using a MK3S. I'm aware how to adjust the live Z, but it is really annoying to have to change it everytime and then remember to set it back. The Z offset was a great and simple feature to address this, plus just going from PLA to PETG I may need to adjust.  Just looking to see if anyone has the same problem before I elevate it github.
Thanks for the advise
Postato : 18/04/2022 10:36 pm
