Z move before xy right before first layer
This is only for using the prusaslicer itself and not a plastic printer which most here are. We have several welder robots and a working cura pp that is doing this xyz start procedure the proper cnc way. I am for the reason of the 'random seam' placement trying to make use of prusaslicer to do the same as cura.
This is however very scary, I ... we do no always weld on flat surfaces but rather in between other parts of the setup, or inside a hole. That means setting the Z axis first then xy cannot be used. Is there a way to fix this glitch?
I have read some topics here about this and was wondering if there was any progress to this topic?
Veröffentlicht : 22/02/2024 12:39 pm
