Z-axis jumps while changing color (2 color print)
Hi there,
i'm doing a batch printing which have two colors. I have no problems if the amount of objects is less then 10. However, when the number is superior and its time to change the color, the Z-axis seams to jump one step from the motor, causing a collision when the printer starts again with the second color.
I'm assuming its a software issue given that it's working with less number of objects in the same batch.
any clue what can cause this?
Thanks
Opublikowany : 17/03/2025 2:07 pm
