        Wrong rotation direction with dual extruder.
Hello.
I've been using prusaslicer for several time and it works fine.
I wanted to test the dual extruder option to print in 2 colours.
When start to print and feed the filament, prints a straight line good.
But when it starts to print, the extruder turns in the opposite direction.
If I use a single extruder option everything goes fine. So my cables are well mounted. Is not hardware problem.
I think problem is with relative extruder movement.
Is there any configuration to do? I cannot find it.
Thanks.
                            Opublikowany : 10/12/2023 5:47 pm
