Wrong direction of bridge over circular void
Pedja
(@pedja)
I have solid body and horizontal hole through all length of body. Slicer made bridge infill in wrong direction - along the void instead across the void.
Slicer is version 2.9.3
Image is attached.
This topic was modified před 6 months by Pedja
Napsal : 29/10/2025 6:48 pm
Print Settings > Infill > Advanced > Bridging angle
Napsal : 29/10/2025 8:09 pm
RE: Wrong direction of bridge over circular void
This is a user to user forum.  If you want to raise bug reports that needs to be done over at the official Prusa Slicer github.  However this has been reported many many times already.  For example https://github.com/prusa3d/PrusaSlicer/issues/4797.
As Diem says just use either the setting or a modifier that contains that setting if you want a specific direction.
Napsal : 29/10/2025 9:21 pm
Pedja
(@pedja)
Thanks. Option to set Bridging angle does help. It sets Bridging angle to all bridges so it is not the best solution, but, I guess, with 45 degrees I could go by in most cases.
Napsal : 30/10/2025 12:22 am
Use modifiers if you want to set them individually.
Napsal : 30/10/2025 3:39 am
