Would like to change starting behavior to avoid glass bed clamps
Dennis M
(@dennis-m-2)
Not sure if this has been addressed before, but I have one issue with PrusaSlicer that I didn't have my any of my former slicers. Basically, the Z height is set first before the move to the initial skirt starting position, which requires me to ensure there isn't a glass bed clip in the way in the lower left corner.
If I edit the gcode manually and make the z-height initial layer adjustment happen *after* the initial x and y coordinates, then the print head moves safely to the starting position while staying out of the way of the bed clips, then it lowers to the initial Z height and begins the skirt.
I hope this makes sense and I'm also hoping there's a way to change this behavior.
Otherwise, the default behavior is that the print head is lowered to the starting z-height before moving to the x, y of the skirt start point. This requires clearance between x, y at 0,0 and the starting position of the skirt. In normal circumstances this would hit the bed clip in the lower left corner.
Veröffentlicht : 11/08/2022 6:14 pm
JustMe3D
(@justme3d)
RE: Would like to change starting behavior to avoid glass bed clamps
Well, it´s named PRUSA Slicer. It´s basically a fork of Slic3r. I would not expect PRUSA Slicer to accomodate glass beds - when did PRUSA ever offer glass beds?
Veröffentlicht : 12/08/2022 8:10 am
Edit your printers profile start gcode section to make it behave how you want.  Must be in expert mode to see the section.
Veröffentlicht : 12/08/2022 8:19 am
towlerg
(@towlerg)
I have a sovol with a glass bed. I decided when I set up the profile (and microswitch positions) such that I had a 10mm unusable area on all four edges.to
I did this because -
  • Doubts about the bed heaters ability to maintain demand temp at extremities.
  • Wanted to use purge line with negative values
  • To avoid the glass clips.
Veröffentlicht : 12/08/2022 5:00 pm
Dennis M
(@dennis-m-2)
@towlerg -- thank you for the useful post and great suggestion. I agree that's one way to avoid the glass clips and might be my only option.
@neophyl -- customizing the start and end gcode is outside the realm of where this problem happens. Any custom "start" gcode happens before the z-height is adjusted down to the first layer height (at x,y = 0) so I can't do anything there.
Veröffentlicht : 20/08/2022 12:08 am
The Prusa Mk1 had a Glass bed, with clips.
Have you considered swiss clips instead of the clips you normally use?
Swiss clips have very little intrusion into the glass surface,
Veröffentlicht : 20/08/2022 5:24 am
Dennis M
(@dennis-m-2)
Thanks Joan, I didn't know about those. Basically what I'm using are small aluminum clips that have a spring loaded thumbturn on the bottom to tighten it up on the bed. Since Prusa moves the z-height to layer 1 before moving to the starting x,y I just have to make sure I locate the front left clip a few inches away from the corner to avoid any nozzle collision.
This method seems like it'll need to be my method since I guess it's going to be challenging to get the PrusaSlicer behavior changed, or I can edit the gcode manually:
Before:
;LAYER_CHANGE; Z:0.3
;HEIGHT:0.3
G1 Z.3 F7800 ; move to next layer (0)
G1 E-6 F3000 ; retract
G92 E0 ; reset extrusion distance
G1 X109.058 Y107.755 F7800 ; move to first skirt point
After:
;LAYER_CHANGE;Z:0.3
;HEIGHT:0.3
Veröffentlicht : 20/08/2022 6:33 am
