With an MMU, how do I move an object on the build plate?
Henry
(@henry-2)
When printing in single filament mode, or without an MMU installed, you can easily move an object on the build plate simply by dragging it. With the MMU installed and selecting a multicolor print, the parts snap back to the center. I need to move my object over to make room for the wipe tower. The only way I can think of to move an object is by adding a second object to the bed. Is there any other way?
Publié : 28/11/2021 11:01 pm
jkavalik
(@jkavalik)
Membre
RE: With an MMU, how do I move an object on the build plate?
Check "Configuration -> Preferences (Ctrl+P)" if you have checked or unchecked "Auto-center parts"
Publié : 29/11/2021 7:54 pm
