Wiping Tower Form
HumpaPrinta
(@humpaprinta)
Wiping Tower Form
Does anyone know if there is a possibility to change the form of the wiping tower?
It would be nice to have it rotateable or even in some L shape to win some net printing place
Respondido : 03/03/2026 9:22 am
RE: Wiping Tower Form
You can change the width of the purge tower, but you need to be in Normal Mode or Expert Mode to view the options
In the example above, I have reduced the width to 30mm
Respondido : 03/03/2026 11:07 am
Miembro
Joan,
Nice find.  Thanks for posting this.  I have had the same question.
Posted by: @joantabb
Respondido : 03/03/2026 11:24 am
HumpaPrinta
(@humpaprinta)
This is something, but for me not "best practice" as it will impact the default cleaning path. 20mm might be enough, even 15mm but i'd prefer a proper solution where when you reduce from 30 to 20, some other value would rise to keep the path. or as suggested, an L shape with "snap to border" feature.
Respondido : 03/03/2026 2:38 pm
Same Old Shane
(@same-old-shane)
Miembro Admin
If you are going for the Tetris / Jenga block bit for the purge / wipe tower... What you could do is find the models of the shape you want, then right click on the object and then select wipe options and you can select both wipe into object and wipe into this objects infill, you would still have the tower to keep the height and depending on the volume of purge and the height, it would still need the regular tower.
Shane (AKA FromPrusa)
Respondido : 03/03/2026 3:50 pm
1 les gusta
HumpaPrinta
(@humpaprinta)
ah, yes, this is a good idea. thanks for that!
Respondido : 04/03/2026 7:19 am
