Wipe tower not available for muti-material supports?
Frank
(@frank-8)
I have a Voron 2.4/300 with the MissChanger mod and PS 2.9.4.  I want to print a model in PETG using PLA supports, but when I select 'supports everywhere', I get an error message saying "the wipe tower currently supports non-soluble supports only if they are printed with the current extruder without triggering a tool change..."
This doesn't make a lot of sense to me - it implies that the wipe tower *does* support soluble supports, but why would the slicer care whether the support filament is soluble or not, and why would I use a wipe tower in the first place if I wasn't doing toolhead changes?
Can someone please explain this to me?  TIA
Frank
Respondido : 02/12/2025 11:00 pm
BaconFase
(@baconfase)
RE: Wipe tower not available for muti-material supports?
Basically, with the stock slicer if you don't have "Top contact Z distance" set to zero then you can't set a specific support extruder while having a wipe tower at the same time.
Respondido : 03/12/2025 11:01 pm
Frank
(@frank-8)
Thanks - I figured that out.
Respondido : 03/12/2025 11:14 pm
RGB
 RGB
(@rgb)
Merci beaucoup, j'attendais cette information depuis très longtemps 😊 👍 👍
Thank you very much, I have been waiting for this information for a very long time 😊 👍 👍
Esta publicación ha sido modificada el hace 2 months por RGB
Prusa i3 MK3S Prusa XL 5 heads Dagoma Disco Ultimate bicolor Creality Ender 3
Respondido : 11/12/2025 8:58 am
