wipe tower
3D color print
(@3d-color-print)
wipe tower
i like to shrink the wipe tower
how can i scale it?
Napsal : 01/08/2019 10:12 am
Dave Avery
(@dave-avery)
RE: wipe tower
in prusaslicer under "print settings" "multiple extruders" " wipe tower" "width"
Napsal : 01/08/2019 10:39 am
3D color print
(@3d-color-print)
RE: wipe tower
after edit of width to half
from standard 60mm to 30mm
it calculates a very long wipe tower
the area looks the same
i like to wipe less
Napsal : 01/08/2019 10:44 am
Sembazuru
(@sembazuru)
RE: wipe tower
* Disclaimer: I don't have an MMU, nor do I have any experience using someone elses MMU. I just watch and listen to others because I might want an MMU in the future.
My impression is the size of the wipe/waste tower is dependent on how much the slicer thinks it needs to purge the previous filament when switching to the next filament. I've heard that there is a setting in PrusaSlicer to purge to infill so the purged plastic is actually used for something other than filling up waste/recycle bins. Try finding that setting to see if it helps. (I would assume that parts with less infill would benefit less from this setting, so as always YMMV.)
See my (limited) designs on:
Napsal : 01/08/2019 3:24 pm
Dave Avery
(@dave-avery)
RE: wipe tower
purge volumes are set on the main screen
Napsal : 01/08/2019 4:15 pm
deonholt
(@deonholt)
RE: wipe tower
@dave-avery
Is there a way to determine/calculate the volume to be purged?
I have just test print my 1st two colour test cube in Cura with a 30mm wipe tower. It wasted a lot of filament. If there was some calculation to know, it would be nice.
Thanks.
Napsal : 13/12/2020 1:21 pm
