Why is PrusaSlicer not complying with my settings for perimeters?
Pfsen
(@pfsen)
I'm tring to print a calibration tower. https://we.tl/t-umrqiD7Esc for the model.
If I set 15 mm^3/s as limit, the perimeters (I have no infill) are printed at 50, 100, 150 mm^3/s depending on the number of perimeters: 1, 2, or 3.
I can get full speed only if I use at least 3 perimeters.
This is not documented anywhere as far as I know.
I want 1 or 2 perimeters because it's a calibration print so I don't care about the look. PSS should comply with my settings, not reduce the values arbitrarily and without any option to disable this behaviour.
Questa discussione è stata modificata 5 years fa 2 tempo da Pfsen
Postato : 12/02/2021 8:20 pm
Pfsen
(@pfsen)
RE: Why is PrusaSlicer not complying with my settings for perimeters?
Sorry, my mistake.
I had "minimum layer time" set.
Once disabled, I'm fine.
Postato : 12/02/2021 8:35 pm
