Why does slicer keep adding this top infill when there is no geometry in my file?
Hey all,
I'm trying to print this hollow vase shape and slicer keeps adding infill when there is no geometry in my .stl file. I have tried removing horizontal layers in the settings but it didn't seem to help. What am I doing wrong?
RE: Why does slicer keep adding this top infill when there is no geometry in my file?
It is properly caused by an error in the STL model. Try running a repair on the model - If on Windows right-click the model and choose repair.
When in Expert mode there will be a warning triangle to the left of the model in the list if it has errors.
@area51
When I fixed the model, it added the unwanted flat part.
I figured it out: Inside my model in Rhino, there was a open polysurface that was being exported with the model, and then Slicer filled it when slicing the model. Thanks for your help!
@andrew-m71
Thanks for the Update Andrew
