Why do some Fusion360 models show up at 10% or 1% of the desired dimensions?
HeneryH
(@heneryh)
I've had this happen several times.  It can't be that so many modelers are stupid.
I must be the stupid one.  Anyone else experience this and how are you solving it?
Napsal : 24/06/2020 11:16 pm
HeneryH
(@heneryh)
RE: Why do some Fusion360 models show up at 10% or 1% of the desired dimensions?
Nevermind, I found out.  It seems STL files don't have dimensions in them so whatever unit your Fusion 360 model is in (the base I started with was in inches) is blindly converted to millimeters 1:1.  So you need to put a scaling factor onto the object in Slicer.
1 inch = 25.4 mm so I need to scale appropriately
This post was modified před 6 years by HeneryH
Napsal : 25/06/2020 12:24 am
Area51
(@area51)
It will be changed in the coming version of PrusaSlicer version 2.3.0, here there is an option to right-click the model and "Convert from imperial unit" to scale the model to millimeters.
Napsal : 25/06/2020 12:48 am
redih67506
(@redih67506)
Posted by: @area51
yeah I agree with you.
Napsal : 28/06/2020 4:04 pm
