Where to download Presets for Filament, Printers, etc?
Sensebellum
(@sensebellum)
Still pretty new to this software but for the life of me I can't seem to be able to download any presets for filament. I only have my user preset from when I setup the software.
I was able to make one for PETG and PLA. But I am really having trouble with FLEX.
Is it at possible to download them? Iread in the help manual that there are only 2 settings to adjust. But then I read to turn off retraction. Should I go slow? I have no idea. Too many settings to brute force through.
Thanks for any tips I am sure the fix is just a click away.
Respondido : 24/07/2020 11:10 pm
1 les gusta
RE: Where to download Presets for Filament, Printers, etc?
Are you using a Prusa or 3rd party printer? There are many filament profiles provided for the Prusa printers. If you run the configuration assistant and add a Prusa, you can "detach" these and save them as custom profiles.
Respondido : 24/07/2020 11:32 pm
Yveske
(@yveske)
This works for me: https://www.prusaprinters.org/prints/12586-ninjaflex-profile-zero-stringing-flawless-print-be
This is for NinjaFlex, but you can hopefully use it as a base for your own brand of filament.
Greetings,
Yveske
Having problems with bed adhesion every morning...
Respondido : 25/07/2020 5:52 am
Sensebellum
(@sensebellum)
Is it possible to just download them?
I played with the configuration assistant but I did not see any menu that helped me download printer or filament presets. It ended up just wiping out what I already had after I selected finish.
I feel like it should be easier to download an entire pack of presets vs reinvent the wheel with no experience.
Are we sure there isn't a repository where we can download them? Still not sure why they didn't come pre-installed...
Thanks!
Respondido : 25/07/2020 8:41 pm
Sensebellum
(@sensebellum)
Is this where you are supposed to download them from?
https://github.com/prusa3d/PrusaSlicer-settings
Respondido : 25/07/2020 8:43 pm
Sensebellum
(@sensebellum)
So I tried installing and I got almost 8 other filaments that are of little use.
Is this really the only way to find presets??
Respondido : 25/07/2020 8:46 pm
Sensebellum
(@sensebellum)
New presets...
Respondido : 25/07/2020 8:47 pm
Yveske
(@yveske)
In PrusaSlicer go to Configuration - Configuration Wizard and you can add all the filaments you want
Respondido : 26/07/2020 5:12 am
2 les gusta
Posted by: @yveske
You can add them but when the wizard is done most of them will only show up if you also have a Prusa printer selected under printer. They are mostly part of the Prusa vendor space so aren’t available to most non Prusa printers. As described above you can select a Prusa printer so you can see the list and then copy it and detach it from the system presets so that it is available to all printers but this it’s a pain in the rear to do.
You could download the following zip file which contains a configuration bundle for filaments I created awhile back. Just extract it and then use file>import config bundle.
GenericFilaments_Neo_20200401
Respondido : 26/07/2020 10:08 am
1 les gusta
Murray Brown
(@murray-brown)
@yveske
I have tried that.  I am unable to add another filament company and their product(s).
Respondido : 12/08/2020 11:42 pm
towlerg
(@towlerg)
I think I saw a vid on YouTube with a work around.
Respondido : 14/08/2020 4:51 am
GregoryHuey
(@gregoryhuey)
This URL yields a 404. Please update.
Respondido : 01/10/2025 12:33 pm
