Where did hollowing in Prusa go?
Yanksy
(@yanksy)
Hey,
I use Chitubox to hollow my models. I read a post about doing it in Prusa and found this - https://help.prusa3d.com/article/hollowing_117285
It says you need 2.2 or newer, but I have 2.5 and I am not seeing it. Am I missing something?
Napsal : 07/01/2023 2:01 am
RE: Where did hollowing in Prusa go?
Hollowing is a function of resin printing, Prusa Slicer only has that option for the SL1 resin printers.  It is not available for fdm.
Napsal : 07/01/2023 2:07 am
Yanksy
(@yanksy)
Oh I see.
I like hollowing them to save a lot on time and filament. Other than a loss to strength why would hollowing not be ok to do in FDM? I am just printing large models to paint.
Napsal : 07/01/2023 2:24 am
Because hollowing isn't needed for fdm.  FDM already prints a shell and if you wanted a completely hollow item then you turn the infill off.  Of course with no infill some geometry might not print but the same problem exists when you hollow a model.
Napsal : 07/01/2023 3:06 am
Yveske
(@yveske)
If you still want hollowing for FDM, first use SL1 as printer profile and export (File - Export - Export plate as stl)
Having problems with bed adhesion every morning...
Napsal : 07/01/2023 9:04 am
2 lidem se líbí
Muslimmingle
(@muslimmingle)
Can we export it to obj as well from Sl1 as printer profile?
Napsal : 08/01/2024 5:36 am
