what is wrong with my bundle
Fatih Hamırcu
(@fatih-hamircu)
When I have sliced the objects, I got error on top of the tower like in the picture.
what is wrong with my bundle?
# generated by PrusaSlicer 2.7.1+win64 on 2023-12-26 at 17:05:14 UTC
[print:4Max Pro 2.0]
arc_fitting = disabled
avoid_crossing_curled_overhangs = 0
avoid_crossing_perimeters = 0
avoid_crossing_perimeters_max_detour = 0
bottom_fill_pattern = alignedrectilinear
bottom_solid_layers = 3
bottom_solid_min_thickness = 1.2
bridge_acceleration = 300
bridge_angle = 0
bridge_flow_ratio = 0.9
bridge_speed = 25
brim_separation = 0
brim_type = outer_only
brim_width = 4
compatible_printers = "Anycubic 4Max Pro 2.0"
compatible_printers_condition =
complete_objects = 0
default_acceleration = 500
dont_support_bridges = 0
draft_shield = disabled
elefant_foot_compensation = 0.25
enable_dynamic_overhang_speeds = 0
external_perimeter_acceleration = 0
external_perimeter_extrusion_width = 0
external_perimeter_speed = 100%
external_perimeters_first = 0
extra_perimeters = 1
extra_perimeters_on_overhangs = 0
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_width = 0.55
fill_angle = 45
fill_density = 20%
fill_pattern = gyroid
first_layer_acceleration = 300
first_layer_acceleration_over_raft = 0
first_layer_extrusion_width = 0.65
first_layer_height = 0.3
first_layer_speed = 15
first_layer_speed_over_raft = 30
fuzzy_skin = none
fuzzy_skin_point_dist = 0.8
fuzzy_skin_thickness = 0.3
gap_fill_enabled = 1
gap_fill_speed = 45
gcode_comments = 0
gcode_label_objects = disabled
gcode_resolution = 0.0125
gcode_substitutions =
infill_acceleration = 600
infill_anchor = 400%
infill_anchor_max = 50
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.6
infill_first = 0
infill_overlap = 23%
infill_speed = 45
inherits =
interface_shells = 0
ironing = 0
ironing_flowrate = 15%
ironing_spacing = 0.1
ironing_speed = 15
ironing_type = top
layer_height = 0.3
max_print_speed = 60
max_volumetric_extrusion_rate_slope_negative = 0
max_volumetric_extrusion_rate_slope_positive = 0
max_volumetric_speed = 0
min_bead_width = 85%
min_feature_size = 25%
min_skirt_length = 0
mmu_segmented_region_interlocking_depth = 0
mmu_segmented_region_max_width = 0
notes = config v7 from hartrusion.com
only_retract_when_crossing_perimeters = 0
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhang_speed_0 = 15
overhang_speed_1 = 15
overhang_speed_2 = 20
overhang_speed_3 = 25
overhangs = 1
perimeter_acceleration = 500
perimeter_extruder = 1
perimeter_extrusion_width = 0.65
perimeter_generator = arachne
perimeter_speed = 45
perimeters = 3
post_process =
print_settings_id =
raft_contact_distance = 0.1
raft_expansion = 1.5
raft_first_layer_density = 90%
raft_first_layer_expansion = 3
raft_layers = 0
resolution = 0
seam_position = aligned
single_extruder_multi_material_priming = 1
skirt_distance = 7
skirt_height = 1
skirts = 2
slice_closing_radius = 0.05
slicing_mode = regular
small_perimeter_speed = 88.8%
solid_infill_acceleration = 0
solid_infill_below_area = 5
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0.8
solid_infill_speed = 88.8%
spiral_vase = 0
staggered_inner_seams = 0
standby_temperature_delta = -5
support_material = 1
support_material_angle = 0
support_material_auto = 0
support_material_bottom_contact_distance = 0
support_material_bottom_interface_layers = -1
support_material_buildplate_only = 0
support_material_closing_radius = 2
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0.45
support_material_interface_contact_loops = 0
support_material_interface_extruder = 1
support_material_interface_layers = 2
support_material_interface_pattern = rectilinear
support_material_interface_spacing = 0.2
support_material_interface_speed = 100%
support_material_pattern = rectilinear-grid
support_material_spacing = 2.5
support_material_speed = 55
support_material_style = grid
support_material_synchronize_layers = 0
support_material_threshold = 0
support_material_with_sheath = 1
support_material_xy_spacing = 50%
support_tree_angle = 40
support_tree_angle_slow = 25
support_tree_branch_diameter = 2
support_tree_branch_diameter_angle = 5
support_tree_branch_diameter_double_wall = 3
support_tree_branch_distance = 1
support_tree_tip_diameter = 0.8
support_tree_top_rate = 15%
thick_bridges = 1
thin_walls = 1
top_fill_pattern = alignedrectilinear
top_infill_extrusion_width = 0
top_solid_infill_acceleration = 0
top_solid_infill_speed = 87.5%
top_solid_layers = 3
top_solid_min_thickness = 1.2
travel_acceleration = 0
travel_speed = 75
travel_speed_z = 0
wall_distribution_count = 1
wall_transition_angle = 10
wall_transition_filter_deviation = 25%
wall_transition_length = 100%
wipe_tower = 0
wipe_tower_bridging = 10
wipe_tower_brim_width = 2
wipe_tower_cone_angle = 0
wipe_tower_extra_spacing = 100%
wipe_tower_extruder = 0
wipe_tower_no_sparse_layers = 0
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 180
wipe_tower_y = 140
xy_size_compensation = 0
[print:Factory ABS @4Max Pro 2.0]
bottom_solid_layers = 6
bridge_acceleration = 500
bridge_angle = 0
bridge_flow_ratio = 0.62
bridge_speed = 50
brim_separation = 0
brim_width = 5
default_acceleration = 1000
external_perimeter_extrusion_width = 0.4
external_perimeter_speed = 30
fill_angle = 45
fill_density = 20%
fill_pattern = grid
first_layer_acceleration = 1000
first_layer_extrusion_width = 0.52
first_layer_speed = 20
fuzzy_skin = none
gap_fill_speed = 15
gcode_comments = 0
infill_acceleration = 1000
infill_extruder = 1
infill_extrusion_width = 0.4
infill_first = 0
infill_speed = 50
inherits =
ironing = 0
ironing_speed = 15
ironing_type = top
layer_height = 0.2
max_print_speed = 50
notes = config v7 from hartrusion.com\nfactory settings as suggested from manufacturer in cura profile
ooze_prevention = 0
overhangs = 1
perimeter_acceleration = 334
perimeter_speed = 50
perimeters = 3
post_process =
print_settings_id =
raft_layers = 0
resolution = 0
skirt_distance = 7
skirt_height = 1
skirts = 0
small_perimeter_speed = 50
solid_infill_extrusion_width = 0.4
solid_infill_speed = 50
spiral_vase = 0
support_material = 0
support_material_angle = 45
support_material_interface_speed = 30
support_material_spacing = 2.667
support_material_speed = 50
support_material_threshold = 60
thick_bridges = 1
thin_walls = 1
top_infill_extrusion_width = 0.4
top_solid_infill_speed = 29
top_solid_layers = 6
travel_speed = 60
travel_speed_z = 0
wipe_tower = 0
wipe_tower_x = 180
wipe_tower_y = 140
[print:Factory PLA,TPU @4Max Pro 2.0]
bridge_angle = 0
bridge_speed = 30
brim_separation = 0
brim_width = 5
fill_angle = 45
fill_density = 20%
fill_pattern = grid
fuzzy_skin = none
gap_fill_speed = 15
gcode_comments = 0
infill_extruder = 1
infill_first = 0
infill_speed = 45
inherits =
ironing = 0
ironing_speed = 15
ironing_type = top
layer_height = 0.2
ooze_prevention = 0
overhangs = 1
perimeters = 3
post_process =
print_settings_id =
raft_layers = 0
resolution = 0
skirt_distance = 7
skirt_height = 1
skirts = 0
small_perimeter_speed = 45
solid_infill_speed = 45
spiral_vase = 0
support_material_speed = 45
thick_bridges = 1
thin_walls = 1
top_solid_infill_speed = 26
travel_speed = 60
travel_speed_z = 0
wipe_tower = 0
wipe_tower_x = 180
wipe_tower_y = 140
[print:MosaicPalette]
avoid_crossing_perimeters = 1
bottom_fill_pattern = concentric
bridge_angle = 0
bridge_speed = 30
brim_separation = 0
brim_type = outer_and_inner
brim_width = 4
compatible_printers_condition = printer_model=="4MAXPRO20" and nozzle_diameter[0]==0.4
default_acceleration = 900
dont_support_bridges = 1
external_perimeter_speed = 25
fill_angle = 45
fill_density = 20%
fill_pattern = lightning
first_layer_height = 0.2
fuzzy_skin = none
gap_fill_speed = 40
gcode_comments = 0
gcode_label_objects = firmware
infill_extruder = 1
infill_first = 0
infill_speed = 45
inherits = 0.20mm Quality @4Max Pro 2.0
ironing = 0
ironing_speed = 15
ironing_type = top
layer_height = 0.2
notes =
ooze_prevention = 0
output_filename_format = {input_filename_base}.mcfx
overhangs = 1
perimeter_generator = classic
perimeters = 2
post_process = "C:\\p2pp\\p2pp.exe"
print_settings_id =
raft_layers = 0
resolution = 0
seam_position = nearest
single_extruder_multi_material_priming = 0
skirt_distance = 5
skirt_height = 1
skirts = 0
small_perimeter_speed = 20
solid_infill_below_area = 0
spiral_vase = 0
support_material_auto = 1
support_material_style = organic
support_material_synchronize_layers = 1
support_material_threshold = 45
support_material_xy_spacing = 60%
thick_bridges = 1
thin_walls = 1
top_fill_pattern = concentric
top_solid_infill_speed = 30
top_solid_layers = 1
travel_speed = 60
travel_speed_z = 0
wipe_tower = 1
wipe_tower_bridging = 15
wipe_tower_width = 40
wipe_tower_x = 60.7741
wipe_tower_y = 33.9468
[print:Quality @4Max Pro 2.0]
bridge_angle = 0
bridge_speed = 30
brim_separation = 0
brim_width = 4
external_perimeter_extrusion_width = 0.45
external_perimeter_speed = 70%
fill_angle = 45
fill_density = 20%
first_layer_height = 0.26
fuzzy_skin = none
gap_fill_speed = 40
gcode_comments = 0
infill_extruder = 1
infill_first = 0
infill_speed = 45
inherits =
ironing = 0
ironing_speed = 15
ironing_type = top
layer_height = 0.2
ooze_prevention = 0
overhangs = 1
perimeters = 4
post_process =
print_settings_id =
raft_layers = 0
resolution = 0
skirt_distance = 7
skirt_height = 1
skirts = 2
small_perimeter_speed = 40%
solid_infill_below_area = 70
spiral_vase = 0
support_material_buildplate_only = 1
thick_bridges = 1
thin_walls = 1
top_solid_infill_speed = 65%
travel_speed = 75
travel_speed_z = 0
wipe_tower = 0
wipe_tower_x = 180
wipe_tower_y = 140
[filament:Anycubic PLA CPL020 White @4Max Pro 2.0]
bed_temperature = 60
bridge_fan_speed = 100
compatible_prints =
compatible_prints_condition =
cooling = 1
disable_fan_first_layers = 4
enable_dynamic_fan_speeds = 0
end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n"
extrusion_multiplier = 1
fan_always_on = 1
fan_below_layer_time = 30
filament_colour = #FFFFFF
filament_cooling_final_speed = 3.4
filament_cooling_initial_speed = 2.2
filament_cooling_moves = 4
filament_cost = 25
filament_density = 1.156
filament_deretract_speed = nil
filament_diameter = 1.75
filament_load_time = 0
filament_loading_speed = 28
filament_loading_speed_start = 3
filament_max_volumetric_speed = 4.5
filament_minimal_purge_on_wipe_tower = 15
filament_multitool_ramming = 0
filament_multitool_ramming_flow = 10
filament_multitool_ramming_volume = 10
filament_notes = "config v7 from hartrusion.com\n195-220 deg C wirtten on spool thingy"
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_retract_before_travel = nil
filament_retract_before_wipe = nil
filament_retract_layer_change = nil
filament_retract_length = 2
filament_retract_length_toolchange = nil
filament_retract_lift = nil
filament_retract_lift_above = nil
filament_retract_lift_below = nil
filament_retract_restart_extra = 0.2
filament_retract_restart_extra_toolchange = nil
filament_retract_speed = nil
filament_settings_id = ""
filament_soluble = 0
filament_spool_weight = 500
filament_toolchange_delay = 0
filament_travel_lift_before_obstacle = nil
filament_travel_max_lift = nil
filament_travel_ramping_lift = nil
filament_travel_slope = nil
filament_type = PLA
filament_unload_time = 0
filament_unloading_speed = 90
filament_unloading_speed_start = 100
filament_vendor = (Unknown)
filament_wipe = nil
first_layer_bed_temperature = 60
first_layer_temperature = 210
full_fan_speed_layer = 8
idle_temperature = nil
inherits =
max_fan_speed = 80
min_fan_speed = 45
min_print_speed = 10
overhang_fan_speed_0 = 0
overhang_fan_speed_1 = 0
overhang_fan_speed_2 = 0
overhang_fan_speed_3 = 0
slowdown_below_layer_time = 15
start_filament_gcode = "; Filament gcode\n"
temperature = 197
[filament:Anycubic PLA D0163 Grey @4Max Pro 2.0]
compatible_prints =
cooling = 1
fan_always_on = 1
filament_colour = #808080
filament_cost = 25
filament_max_volumetric_speed = 0
filament_notes = "config v7 from hartrusion.com\n190-230 deg C written on box, 200-230 deg C wirtten on spool thingy"
filament_retract_length = 2.7
filament_retract_speed = 45
filament_spool_weight = 1000
filament_type = PLA
filament_wipe = nil
first_layer_temperature = 215
full_fan_speed_layer = 10
inherits =
max_fan_speed = 60
min_fan_speed = 35
temperature = 207
[filament:Factory ABS @4Max Pro 2.0]
bed_temperature = 100
bridge_fan_speed = 0
compatible_prints =
cooling = 1
disable_fan_first_layers = 3
fan_always_on = 0
fan_below_layer_time = 60
filament_colour = #800000
filament_cost = 0
filament_density = 0
filament_notes = "config v7 from hartrusion.com"
filament_retract_length = nil
filament_retract_restart_extra = nil
filament_spool_weight = 0
filament_type = ABS
filament_wipe = nil
first_layer_bed_temperature = 100
first_layer_temperature = 245
full_fan_speed_layer = 0
inherits =
max_fan_speed = 0
min_fan_speed = 0
slowdown_below_layer_time = 5
temperature = 245
[filament:Factory PLA @4Max Pro 2.0]
compatible_prints =
cooling = 1
disable_fan_first_layers = 2
fan_always_on = 1
fan_below_layer_time = 10
filament_colour = #CCC5BD
filament_cost = 0
filament_notes = "config v7 from hartrusion.com\nSuggested temps in printer manual: 205 deg C with bed temp 60 deg C "
filament_retract_layer_change = 0
filament_retract_length = 2.5
filament_retract_speed = 30
filament_type = PLA
filament_wipe = nil
first_layer_temperature = 205
inherits =
max_fan_speed = 100
min_fan_speed = 10
temperature = 205
[filament:Factory TPU @4Max Pro 2.0]
compatible_prints =
cooling = 1
fan_always_on = 0
filament_colour = #211AB5
filament_cost = 0
filament_density = 1.19
filament_notes = "config v7 from hartrusion.com\nmax4 manual: print head 215, bed 60"
filament_type = PLA
filament_wipe = nil
inherits =
max_fan_speed = 0
min_fan_speed = 0
temperature = 215
[filament:FilaFlex 82A @4Max Pro 2.0]
bed_temperature = 30
bridge_fan_speed = 80
compatible_prints =
cooling = 1
disable_fan_first_layers = 5
end_filament_gcode = "; Filament-specific end gcode \n; G91 ; relative positioning\n; G1 E-5 F300 ; retract the filament to release pressure\n;END gcode for filament\n"
extrusion_multiplier = 1.113
fan_always_on = 1
fan_below_layer_time = 45
filament_colour = #2B3033
filament_cost = 69.8
filament_density = 1.12
filament_deretract_speed = 45
filament_max_volumetric_speed = 1.26
filament_notes = "config v7 from hartrusion.com\nto avoid oozing, use the avoid crossing perimeters option"
filament_retract_before_travel = 1
filament_retract_layer_change = 1
filament_retract_length = 8.5
filament_retract_restart_extra = 0.5
filament_retract_speed = 60
filament_settings_id = "FilaFlex 82A @4Max Pro 2.0"
filament_type = TPU
filament_wipe = nil
first_layer_bed_temperature = 40
first_layer_temperature = 235
inherits =
max_fan_speed = 45
min_fan_speed = 25
slowdown_below_layer_time = 10
temperature = 234
[filament:FilaFlex Pro 60A @4Max Pro 2.0]
compatible_prints =
cooling = 1
extrusion_multiplier = 1.13
fan_always_on = 1
filament_colour = #31443F
filament_cost = 99.8
filament_deretract_speed = 25
filament_max_volumetric_speed = 1.1
filament_retract_restart_extra = 0.3
filament_settings_id = "Filaflex 82A @4Max Pro 2.0"
filament_type = TPU
filament_wipe = nil
first_layer_temperature = 222
full_fan_speed_layer = 4
inherits =
max_fan_speed = 50
min_fan_speed = 35
temperature = 218
[filament:Mvs ABS @4Max Pro 2.0]
compatible_prints =
cooling = 1
fan_always_on = 0
filament_colour = #C6E100
filament_cost = 24
filament_density = 1.04
filament_notes = "config v7 from hartrusion.com\nfilament bought from super-filament.de on ebay, probably brand is MVS\nrecommended nozzle: 190 to 230 deg C, bed 80 to 100 deg C"
filament_type = ABS
filament_wipe = nil
inherits =
max_fan_speed = 0
min_fan_speed = 0
slowdown_below_layer_time = 25
temperature = 240
[filament:PLA]
compatible_printers_condition = printer_notes!~/.*NO_TEMPLATES.*/ and printer_notes!~/.*PRINTER_VENDOR_TRILAB.*/ and printer_notes!~/.*PRINTER_MODEL_MK4IS.*/ and ! (printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and num_extruders>1)
compatible_prints =
cooling = 1
end_filament_gcode = "; Filament-specific end gcode"
fan_always_on = 1
fan_below_layer_time = 100
filament_colour = #0080FF
filament_cooling_final_speed = 0
filament_cooling_initial_speed = 0
filament_cooling_moves = 0
filament_cost = 27.82
filament_density = 1.24
filament_loading_speed = 0
filament_loading_speed_start = 0
filament_max_volumetric_speed = 15
filament_minimal_purge_on_wipe_tower = 0
filament_notes = ""
filament_ramming_parameters = "130 120 2.70968 2.93548 3.32258 3.83871 4.58065 5.54839 6.51613 7.35484 7.93548 8.16129| 0.05 2.66451 0.45 3.05805 0.95 4.05807 1.45 5.97742 1.95 7.69999 2.45 8.1936 2.95 11.342 3.45 11.4065 3.95 7.6 4.45 7.6 4.95 7.6"
filament_spool_weight = 230
filament_type = PLA
filament_unloading_speed = 0
filament_unloading_speed_start = 0
filament_vendor = Made for Prusa
filament_wipe = nil
first_layer_temperature = 230
idle_temperature = 70
inherits = Prusa PLA @Template
max_fan_speed = 55
min_fan_speed = 33
min_print_speed = 15
slowdown_below_layer_time = 8
temperature = 210
[filament:PolyFlex TPU95 @4Max Pro 2.0]
bed_temperature = 45
compatible_prints =
cooling = 1
end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-5 F300 ; retract the filament to release pressure\n;END gcode for filament\n"
extrusion_multiplier = 1.04
fan_always_on = 1
filament_colour = #FD7D2F
filament_cost = 67.7
filament_density = 1.22
filament_max_volumetric_speed = 1.65
filament_retract_length = 4
filament_retract_restart_extra = 0.1
filament_spool_weight = 750
filament_type = TPU
filament_wipe = nil
first_layer_bed_temperature = 55
inherits =
max_fan_speed = 50
min_fan_speed = 25
temperature = 217
[filament:PolyMide CoPA @4Max Pro 2.0]
bridge_fan_speed = 30
compatible_prints =
cooling = 1
end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;M104 S0 ; turn off extruder heating\n;G28 X0 Y0 ; goto x and y home\n;M140 S70 ; set bed temp to 70 degrees to anneal the print for 2 hours inside the printer\n;M117 annealing\n;G4 S54000 ; wait 2 hrs\n;END gcode for filament\n"
fan_always_on = 1
filament_colour = #D6D894
filament_cost = 92.67
filament_max_volumetric_speed = 2.4
filament_notes = "config v7 from hartrusion.com\nto avoid edge curling, increase layer height"
filament_type = NYLON
filament_wipe = nil
first_layer_bed_temperature = 50
first_layer_temperature = 255
full_fan_speed_layer = 6
inherits =
max_fan_speed = 25
min_fan_speed = 20
slowdown_below_layer_time = 40
temperature = 253
[filament:RedPLA]
compatible_prints =
cooling = 1
fan_always_on = 1
filament_colour = #FF0000
filament_notes = ""
filament_type = PLA
filament_wipe = nil
max_fan_speed = 55
min_fan_speed = 33
temperature = 210
[filament:filatech HIPS @4Max Pro 2.0]
bed_temperature = 110
bridge_fan_speed = 50
compatible_prints =
cooling = 1
fan_always_on = 1
filament_colour = #EEEEE8
filament_cost = 25
filament_type = HIPS
filament_wipe = nil
first_layer_bed_temperature = 105
first_layer_temperature = 225
inherits =
max_fan_speed = 45
min_fan_speed = 20
temperature = 220
[filament:yourDroid TPU @4Max Pro 2.0]
bridge_fan_speed = 45
compatible_prints =
cooling = 0
fan_always_on = 1
filament_colour = #1FC216
filament_cost = 36.9
filament_density = 1.18
filament_deretract_speed = 20
filament_notes = "config v7 from hartrusion.com\nseller description: printing temperature: 205-230, plattform 0-70\nupdated with v5"
filament_retract_speed = 50
filament_type = TPU
filament_wipe = nil
full_fan_speed_layer = 15
inherits =
max_fan_speed = 100
min_fan_speed = 10
temperature = 205
[printer:AnycubicPalette3Pro]
autoemit_temperature_commands = 1
bed_custom_model =
bed_custom_texture =
bed_shape = 0x0,270x0,270x210,0x210
before_layer_gcode = ;BEFORE_LAYER_CHANGE G92 E0
between_objects_gcode =
binary_gcode = 0
color_change_gcode = M600
cooling_tube_length = 0
cooling_tube_retraction = 0
default_filament_profile = "Generic PLA @4Max Pro 2.0"
default_print_profile = 0.20mm Quality @4Max Pro 2.0
deretract_speed = 0,25,25,25,25,25,25,25
end_gcode = M104 S0 ; turn off extruder heating\nM140 S0 ; turn off bed heating\nM107 ; turn off fans\nG91 ; relative positioning\nG0 Z+0.5 ; move Z up a tiny bit\nG90 ; absolute positioning\nG0 X135 Y105 F{machine_max_feedrate_x[0]*60} ; move extruder to center position\nG0 Z190.5 F{machine_max_feedrate_z[0]*60} ; lower the plattform to Z min\nM84 ; steppers off\nM106 S255 ; cool down part cooling fan nozzle\nG4 P30 ; for about 30 seconds\nM107 ; turn off fan\nG90 ; absolute positioning\nM300 P300 S4000 ; make some beep that print is finished\n
extra_loading_move = 0
extruder_colour = #0080FF;#FF0000;;;;;;
extruder_offset = 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0
gcode_flavor = marlin
high_current_on_filament_swap = 0
host_type = prusalink
inherits = Anycubic 4Max Pro 2.0
layer_gcode = ;AFTER_LAYER_CHANGE\n;LAYER [layer_num]\n;LAYERHEIGHT [layer_z]\nG92 E0
machine_limits_usage = time_estimate_only
machine_max_acceleration_e = 5000
machine_max_acceleration_extruding = 1250
machine_max_acceleration_retracting = 1250
machine_max_acceleration_travel = 1500
machine_max_acceleration_x = 900
machine_max_acceleration_y = 900
machine_max_acceleration_z = 100
machine_max_feedrate_e = 120
machine_max_feedrate_x = 200
machine_max_feedrate_y = 200
machine_max_feedrate_z = 16
machine_max_jerk_e = 5
machine_max_jerk_x = 6
machine_max_jerk_y = 6
machine_max_jerk_z = 0.2
machine_min_extruding_rate = 0
machine_min_travel_rate = 0
max_layer_height = 0.2,0.2,0.2,0.2,0.2,0.2,0.2,0.2
max_print_height = 190
min_layer_height = 0.2,0.2,0.2,0.2,0.2,0.2,0.2,0.2
nozzle_diameter = 0.4,0.4,0.4,0.4,0.4,0.4,0.4,0.4
parking_pos_retraction = 0
pause_print_gcode = M601
print_host =
printer_model = 4MAXPRO20
printer_notes =
printer_settings_id =
printer_technology = FFF
printer_variant = 0.4
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_before_travel = 1,2,2,2,2,2,2,2
retract_before_wipe = 0%,0%,0%,0%,0%,0%,0%,0%
retract_layer_change = 1,1,1,1,1,1,1,1
retract_length = 0.8,2.5,2.5,2.5,2.5,2.5,2.5,2.5
retract_length_toolchange = 10,10,10,10,10,10,10,10
retract_lift = 0.05,0.05,0.05,0.05,0.05,0.05,0.05,0.05
retract_lift_above = 0,0,0,0,0,0,0,0
retract_lift_below = 0,0,0,0,0,0,0,0
retract_restart_extra = 0,0,0,0,0,0,0,0
retract_restart_extra_toolchange = 0,0,0,0,0,0,0,0
retract_speed = 35,35,35,35,35,35,35,35
silent_mode = 0
single_extruder_multi_material = 1
start_gcode = G21 ; metric values\nG90 ; absolute positioning\nM82 ; set extruder to absolute mode\nM140 S[first_layer_bed_temperature] ; set bed temp\nG28 X0 Y0 ; home X and Y\nG28 Z0 ; home Z\nG1 Z30 F{machine_max_feedrate_z[0]*60} ; move Z a bit down to not blow on the bed edge while heating\nG1 X10 F3900 ; let some space on x to prevent the filament cooling exhaust from beeing blocked by the servo motor\nM190 S[first_layer_bed_temperature] ; wait for bed temp\nM104 S[first_layer_temperature] ; set extruder temp\nM106 S80 ; turn on fan to prevent air nozzle melt while heating up\nM109 S[first_layer_temperature] ; wait for extruder temp\nM107 ; start with the fan off\nG28 X0 ; goto X home again\nG92 E0 ; zero the extruded length\nG1 Z0.2 F360 ; move plattform upwards\n; extrude material next to the plattform (comment or remove following lines to disable)\nG1 F180 E20 ; extrude some material next to the plattform\nG92 E0 ; zero the extruded length\nG1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract\nG92 E0 ; zero the extruded length again\nG1 X5 F3900 ; move sideways to get rid of that string\nG1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters\nG92 E0 ; zero the extruded length again\n; draw intro line (comment or remove following lines to disable)\nG1 X30 E5 F700 ; draw intro line\nG92 E0 ; zero the extruded length\nG1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract\nG1 X40 Z2.0 ; move away from the introline\nG92 E0 ; zero the extruded length again\nG1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters\n; end of intro line code\nG1 F100 ; from sample code dunno why its here\nM117 Printing...\n\n;P2PP PALETTE3_PRO\n;P2PP PALETTE3_PRO\n;P2PP PRINTERPROFILE=c93e2561cf74459fa3ca7a797ad16066\n\n;P2PP SPLICEOFFSET=40\n\n;P2PP MINSTARTSPLICE=130\n;P2PP MINSPLICE=90\n\n;P2PP EXTRAENDFILAMENT=150\n;P2PP LINEARPINGLENGTH=350\n\n;P2PP FILAMENTOVERRIDE=RedPLA\n;P2PP MATERIAL_PLA_PLA_2_1_2\n;P2PP MATERIAL_PLA_RedPLA_2_1_2\n;P2PP MATERIAL_RedPLA_PLA_2_1_2\n\n;set P2PP ABSOLUTEEXTRUDER\n;P2PP PURGETOWERDELTA=0\n\n;P2PP FULLPURGEREDUCTION \n;P2PP WIPEFEEDRATE=3000\n;P2PP AUTOADDPURGE \n\n;P2PP TEMPERATURECONTROL\n\nG5\n
template_custom_gcode =
thumbnails = 640x480/PNG
thumbnails_format = PNG
toolchange_gcode =
travel_lift_before_obstacle = 0,0,0,0,0,0,0,0
travel_max_lift = 0,0,0,0,0,0,0,0
travel_ramping_lift = 0,0,0,0,0,0,0,0
travel_slope = 0,0,0,0,0,0,0,0
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
variable_layer_height = 0
wipe = 1,0,0,0,0,0,0,0
z_offset = 0
[presets]
print = MosaicPalette
sla_print =
sla_material =
printer = AnycubicPalette3Pro
filament = PLA
filament_1 = RedPLA
filament_2 = PLA
filament_3 = PLA
filament_4 = RedPLA
filament_5 = RedPLA
filament_6 = RedPLA
filament_7 = RedPLA
physical_printer =
Best Answer by Neophyl:
First of all welcome. Secondly can you not post long lists that are impossible to go through, if you want to post that info the simplest way is to save a project from PRUSA slicer (file>save project as)and the 3mf saved will contain a copy of all 3 profiles in use as well as any models and modifiers etc. The only thing to remember is that all files attached should be zipped up or the forum here will just silently not attach them. No warnings.
As to your specific issue, there is no issue.  It is deliberately programmed to do that. Someone else very recently also asked this same question. It’s currently on the second page of this very sub forum, https://forum.prusa3d.com/forum/prusaslicer/finishing-wipe-tower-in-mid-air/
Respondido : 26/12/2023 5:06 pm
Gearloose99 me gusta
BaconFase
(@baconfase)
RE: what is wrong with my bundle
That's just the final purge at the end of the print.
XL-5T, MK3S MMU3 || GUIDE: How to print with multiple-nozzlesizes do read updated replies || PrusaSlicer Fork with multi-nozzlesize freedom || How Feasible is Printing PETG for PLA supports on XL very
Respondido : 26/12/2023 7:59 pm
As BaconFase said. And please, don't include pages of configs that are hard to parse. Much better is to upload a zipped 3mf project file saved from Prusaslicer, which contains all your settings and makes it much easier to see if anything is suspicious.
Respondido : 26/12/2023 9:14 pm
Respondido : 26/12/2023 11:28 pm
