what is wrong with my bundle
When I have sliced the objects, I got error on top of the tower like in the picture.
what is wrong with my bundle?
# generated by PrusaSlicer 2.7.1+win64 on 2023-12-26 at 17:05:14 UTC [print:4Max Pro 2.0] arc_fitting = disabled avoid_crossing_curled_overhangs = 0 avoid_crossing_perimeters = 0 avoid_crossing_perimeters_max_detour = 0 bottom_fill_pattern = alignedrectilinear bottom_solid_layers = 3 bottom_solid_min_thickness = 1.2 bridge_acceleration = 300 bridge_angle = 0 bridge_flow_ratio = 0.9 bridge_speed = 25 brim_separation = 0 brim_type = outer_only brim_width = 4 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = complete_objects = 0 default_acceleration = 500 dont_support_bridges = 0 draft_shield = disabled elefant_foot_compensation = 0.25 enable_dynamic_overhang_speeds = 0 external_perimeter_acceleration = 0 external_perimeter_extrusion_width = 0 external_perimeter_speed = 100% external_perimeters_first = 0 extra_perimeters = 1 extra_perimeters_on_overhangs = 0 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.55 fill_angle = 45 fill_density = 20% fill_pattern = gyroid first_layer_acceleration = 300 first_layer_acceleration_over_raft = 0 first_layer_extrusion_width = 0.65 first_layer_height = 0.3 first_layer_speed = 15 first_layer_speed_over_raft = 30 fuzzy_skin = none fuzzy_skin_point_dist = 0.8 fuzzy_skin_thickness = 0.3 gap_fill_enabled = 1 gap_fill_speed = 45 gcode_comments = 0 gcode_label_objects = disabled gcode_resolution = 0.0125 gcode_substitutions = infill_acceleration = 600 infill_anchor = 400% infill_anchor_max = 50 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.6 infill_first = 0 infill_overlap = 23% infill_speed = 45 inherits = interface_shells = 0 ironing = 0 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_height = 0.3 max_print_speed = 60 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_bead_width = 85% min_feature_size = 25% min_skirt_length = 0 mmu_segmented_region_interlocking_depth = 0 mmu_segmented_region_max_width = 0 notes = config v7 from hartrusion.com only_retract_when_crossing_perimeters = 0 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhang_speed_0 = 15 overhang_speed_1 = 15 overhang_speed_2 = 20 overhang_speed_3 = 25 overhangs = 1 perimeter_acceleration = 500 perimeter_extruder = 1 perimeter_extrusion_width = 0.65 perimeter_generator = arachne perimeter_speed = 45 perimeters = 3 post_process = print_settings_id = raft_contact_distance = 0.1 raft_expansion = 1.5 raft_first_layer_density = 90% raft_first_layer_expansion = 3 raft_layers = 0 resolution = 0 seam_position = aligned single_extruder_multi_material_priming = 1 skirt_distance = 7 skirt_height = 1 skirts = 2 slice_closing_radius = 0.05 slicing_mode = regular small_perimeter_speed = 88.8% solid_infill_acceleration = 0 solid_infill_below_area = 5 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.8 solid_infill_speed = 88.8% spiral_vase = 0 staggered_inner_seams = 0 standby_temperature_delta = -5 support_material = 1 support_material_angle = 0 support_material_auto = 0 support_material_bottom_contact_distance = 0 support_material_bottom_interface_layers = -1 support_material_buildplate_only = 0 support_material_closing_radius = 2 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.45 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 2 support_material_interface_pattern = rectilinear support_material_interface_spacing = 0.2 support_material_interface_speed = 100% support_material_pattern = rectilinear-grid support_material_spacing = 2.5 support_material_speed = 55 support_material_style = grid support_material_synchronize_layers = 0 support_material_threshold = 0 support_material_with_sheath = 1 support_material_xy_spacing = 50% support_tree_angle = 40 support_tree_angle_slow = 25 support_tree_branch_diameter = 2 support_tree_branch_diameter_angle = 5 support_tree_branch_diameter_double_wall = 3 support_tree_branch_distance = 1 support_tree_tip_diameter = 0.8 support_tree_top_rate = 15% thick_bridges = 1 thin_walls = 1 top_fill_pattern = alignedrectilinear top_infill_extrusion_width = 0 top_solid_infill_acceleration = 0 top_solid_infill_speed = 87.5% top_solid_layers = 3 top_solid_min_thickness = 1.2 travel_acceleration = 0 travel_speed = 75 travel_speed_z = 0 wall_distribution_count = 1 wall_transition_angle = 10 wall_transition_filter_deviation = 25% wall_transition_length = 100% wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_brim_width = 2 wipe_tower_cone_angle = 0 wipe_tower_extra_spacing = 100% wipe_tower_extruder = 0 wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 180 wipe_tower_y = 140 xy_size_compensation = 0 [print:Factory ABS @4Max Pro 2.0] arc_fitting = disabled avoid_crossing_curled_overhangs = 0 avoid_crossing_perimeters = 0 avoid_crossing_perimeters_max_detour = 0 bottom_fill_pattern = alignedrectilinear bottom_solid_layers = 6 bottom_solid_min_thickness = 1.2 bridge_acceleration = 500 bridge_angle = 0 bridge_flow_ratio = 0.62 bridge_speed = 50 brim_separation = 0 brim_type = outer_only brim_width = 5 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = complete_objects = 0 default_acceleration = 1000 dont_support_bridges = 0 draft_shield = disabled elefant_foot_compensation = 0.25 enable_dynamic_overhang_speeds = 0 external_perimeter_acceleration = 0 external_perimeter_extrusion_width = 0.4 external_perimeter_speed = 30 external_perimeters_first = 0 extra_perimeters = 1 extra_perimeters_on_overhangs = 0 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.4 fill_angle = 45 fill_density = 20% fill_pattern = grid first_layer_acceleration = 1000 first_layer_acceleration_over_raft = 0 first_layer_extrusion_width = 0.52 first_layer_height = 0.3 first_layer_speed = 20 first_layer_speed_over_raft = 30 fuzzy_skin = none fuzzy_skin_point_dist = 0.8 fuzzy_skin_thickness = 0.3 gap_fill_enabled = 1 gap_fill_speed = 15 gcode_comments = 0 gcode_label_objects = disabled gcode_resolution = 0.0125 gcode_substitutions = infill_acceleration = 1000 infill_anchor = 400% infill_anchor_max = 50 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.4 infill_first = 0 infill_overlap = 23% infill_speed = 50 inherits = interface_shells = 0 ironing = 0 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_height = 0.2 max_print_speed = 50 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_bead_width = 85% min_feature_size = 25% min_skirt_length = 0 mmu_segmented_region_interlocking_depth = 0 mmu_segmented_region_max_width = 0 notes = config v7 from hartrusion.com\nfactory settings as suggested from manufacturer in cura profile only_retract_when_crossing_perimeters = 0 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhang_speed_0 = 15 overhang_speed_1 = 15 overhang_speed_2 = 20 overhang_speed_3 = 25 overhangs = 1 perimeter_acceleration = 334 perimeter_extruder = 1 perimeter_extrusion_width = 0.4 perimeter_generator = arachne perimeter_speed = 50 perimeters = 3 post_process = print_settings_id = raft_contact_distance = 0.1 raft_expansion = 1.5 raft_first_layer_density = 90% raft_first_layer_expansion = 3 raft_layers = 0 resolution = 0 seam_position = aligned single_extruder_multi_material_priming = 1 skirt_distance = 7 skirt_height = 1 skirts = 0 slice_closing_radius = 0.05 slicing_mode = regular small_perimeter_speed = 50 solid_infill_acceleration = 0 solid_infill_below_area = 5 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.4 solid_infill_speed = 50 spiral_vase = 0 staggered_inner_seams = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 45 support_material_auto = 0 support_material_bottom_contact_distance = 0 support_material_bottom_interface_layers = -1 support_material_buildplate_only = 0 support_material_closing_radius = 2 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.45 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 2 support_material_interface_pattern = rectilinear support_material_interface_spacing = 0.2 support_material_interface_speed = 30 support_material_pattern = rectilinear-grid support_material_spacing = 2.667 support_material_speed = 50 support_material_style = grid support_material_synchronize_layers = 0 support_material_threshold = 60 support_material_with_sheath = 1 support_material_xy_spacing = 50% support_tree_angle = 40 support_tree_angle_slow = 25 support_tree_branch_diameter = 2 support_tree_branch_diameter_angle = 5 support_tree_branch_diameter_double_wall = 3 support_tree_branch_distance = 1 support_tree_tip_diameter = 0.8 support_tree_top_rate = 15% thick_bridges = 1 thin_walls = 1 top_fill_pattern = alignedrectilinear top_infill_extrusion_width = 0.4 top_solid_infill_acceleration = 0 top_solid_infill_speed = 29 top_solid_layers = 6 top_solid_min_thickness = 1.2 travel_acceleration = 0 travel_speed = 60 travel_speed_z = 0 wall_distribution_count = 1 wall_transition_angle = 10 wall_transition_filter_deviation = 25% wall_transition_length = 100% wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_brim_width = 2 wipe_tower_cone_angle = 0 wipe_tower_extra_spacing = 100% wipe_tower_extruder = 0 wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 180 wipe_tower_y = 140 xy_size_compensation = 0 [print:Factory PLA,TPU @4Max Pro 2.0] arc_fitting = disabled avoid_crossing_curled_overhangs = 0 avoid_crossing_perimeters = 0 avoid_crossing_perimeters_max_detour = 0 bottom_fill_pattern = alignedrectilinear bottom_solid_layers = 6 bottom_solid_min_thickness = 1.2 bridge_acceleration = 500 bridge_angle = 0 bridge_flow_ratio = 0.62 bridge_speed = 30 brim_separation = 0 brim_type = outer_only brim_width = 5 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = complete_objects = 0 default_acceleration = 1000 dont_support_bridges = 0 draft_shield = disabled elefant_foot_compensation = 0.25 enable_dynamic_overhang_speeds = 0 external_perimeter_acceleration = 0 external_perimeter_extrusion_width = 0.4 external_perimeter_speed = 30 external_perimeters_first = 0 extra_perimeters = 1 extra_perimeters_on_overhangs = 0 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.4 fill_angle = 45 fill_density = 20% fill_pattern = grid first_layer_acceleration = 1000 first_layer_acceleration_over_raft = 0 first_layer_extrusion_width = 0.52 first_layer_height = 0.3 first_layer_speed = 20 first_layer_speed_over_raft = 30 fuzzy_skin = none fuzzy_skin_point_dist = 0.8 fuzzy_skin_thickness = 0.3 gap_fill_enabled = 1 gap_fill_speed = 15 gcode_comments = 0 gcode_label_objects = disabled gcode_resolution = 0.0125 gcode_substitutions = infill_acceleration = 1000 infill_anchor = 400% infill_anchor_max = 50 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.4 infill_first = 0 infill_overlap = 23% infill_speed = 45 inherits = interface_shells = 0 ironing = 0 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_height = 0.2 max_print_speed = 50 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_bead_width = 85% min_feature_size = 25% min_skirt_length = 0 mmu_segmented_region_interlocking_depth = 0 mmu_segmented_region_max_width = 0 notes = config v7 from hartrusion.com\nfactory settings as suggested from manufacturer in cura profile only_retract_when_crossing_perimeters = 0 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhang_speed_0 = 15 overhang_speed_1 = 15 overhang_speed_2 = 20 overhang_speed_3 = 25 overhangs = 1 perimeter_acceleration = 334 perimeter_extruder = 1 perimeter_extrusion_width = 0.4 perimeter_generator = arachne perimeter_speed = 50 perimeters = 3 post_process = print_settings_id = raft_contact_distance = 0.1 raft_expansion = 1.5 raft_first_layer_density = 90% raft_first_layer_expansion = 3 raft_layers = 0 resolution = 0 seam_position = aligned single_extruder_multi_material_priming = 1 skirt_distance = 7 skirt_height = 1 skirts = 0 slice_closing_radius = 0.05 slicing_mode = regular small_perimeter_speed = 45 solid_infill_acceleration = 0 solid_infill_below_area = 5 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.4 solid_infill_speed = 45 spiral_vase = 0 staggered_inner_seams = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 45 support_material_auto = 0 support_material_bottom_contact_distance = 0 support_material_bottom_interface_layers = -1 support_material_buildplate_only = 0 support_material_closing_radius = 2 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.45 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 2 support_material_interface_pattern = rectilinear support_material_interface_spacing = 0.2 support_material_interface_speed = 30 support_material_pattern = rectilinear-grid support_material_spacing = 2.667 support_material_speed = 45 support_material_style = grid support_material_synchronize_layers = 0 support_material_threshold = 60 support_material_with_sheath = 1 support_material_xy_spacing = 50% support_tree_angle = 40 support_tree_angle_slow = 25 support_tree_branch_diameter = 2 support_tree_branch_diameter_angle = 5 support_tree_branch_diameter_double_wall = 3 support_tree_branch_distance = 1 support_tree_tip_diameter = 0.8 support_tree_top_rate = 15% thick_bridges = 1 thin_walls = 1 top_fill_pattern = alignedrectilinear top_infill_extrusion_width = 0.4 top_solid_infill_acceleration = 0 top_solid_infill_speed = 26 top_solid_layers = 6 top_solid_min_thickness = 1.2 travel_acceleration = 0 travel_speed = 60 travel_speed_z = 0 wall_distribution_count = 1 wall_transition_angle = 10 wall_transition_filter_deviation = 25% wall_transition_length = 100% wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_brim_width = 2 wipe_tower_cone_angle = 0 wipe_tower_extra_spacing = 100% wipe_tower_extruder = 0 wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 180 wipe_tower_y = 140 xy_size_compensation = 0 [print:MosaicPalette] arc_fitting = disabled avoid_crossing_curled_overhangs = 0 avoid_crossing_perimeters = 1 avoid_crossing_perimeters_max_detour = 0 bottom_fill_pattern = concentric bottom_solid_layers = 3 bottom_solid_min_thickness = 1.2 bridge_acceleration = 300 bridge_angle = 0 bridge_flow_ratio = 0.9 bridge_speed = 30 brim_separation = 0 brim_type = outer_and_inner brim_width = 4 compatible_printers = compatible_printers_condition = printer_model=="4MAXPRO20" and nozzle_diameter[0]==0.4 complete_objects = 0 default_acceleration = 900 dont_support_bridges = 1 draft_shield = disabled elefant_foot_compensation = 0.25 enable_dynamic_overhang_speeds = 0 external_perimeter_acceleration = 0 external_perimeter_extrusion_width = 0 external_perimeter_speed = 25 external_perimeters_first = 0 extra_perimeters = 1 extra_perimeters_on_overhangs = 0 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.45 fill_angle = 45 fill_density = 20% fill_pattern = lightning first_layer_acceleration = 300 first_layer_acceleration_over_raft = 0 first_layer_extrusion_width = 0.65 first_layer_height = 0.2 first_layer_speed = 20 first_layer_speed_over_raft = 30 fuzzy_skin = none fuzzy_skin_point_dist = 0.8 fuzzy_skin_thickness = 0.3 gap_fill_enabled = 1 gap_fill_speed = 40 gcode_comments = 0 gcode_label_objects = firmware gcode_resolution = 0.0125 gcode_substitutions = infill_acceleration = 600 infill_anchor = 400% infill_anchor_max = 50 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_overlap = 23% infill_speed = 45 inherits = 0.20mm Quality @4Max Pro 2.0 interface_shells = 0 ironing = 0 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_height = 0.2 max_print_speed = 50 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_bead_width = 85% min_feature_size = 25% min_skirt_length = 0 mmu_segmented_region_interlocking_depth = 0 mmu_segmented_region_max_width = 0 notes = only_retract_when_crossing_perimeters = 0 ooze_prevention = 0 output_filename_format = {input_filename_base}.mcfx overhang_speed_0 = 15 overhang_speed_1 = 15 overhang_speed_2 = 20 overhang_speed_3 = 25 overhangs = 1 perimeter_acceleration = 500 perimeter_extruder = 1 perimeter_extrusion_width = 0.65 perimeter_generator = classic perimeter_speed = 45 perimeters = 2 post_process = "C:\\p2pp\\p2pp.exe" print_settings_id = raft_contact_distance = 0.1 raft_expansion = 1.5 raft_first_layer_density = 90% raft_first_layer_expansion = 3 raft_layers = 0 resolution = 0 seam_position = nearest single_extruder_multi_material_priming = 0 skirt_distance = 5 skirt_height = 1 skirts = 0 slice_closing_radius = 0.05 slicing_mode = regular small_perimeter_speed = 20 solid_infill_acceleration = 0 solid_infill_below_area = 0 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 45 spiral_vase = 0 staggered_inner_seams = 0 standby_temperature_delta = -5 support_material = 1 support_material_angle = 0 support_material_auto = 1 support_material_bottom_contact_distance = 0 support_material_bottom_interface_layers = -1 support_material_buildplate_only = 0 support_material_closing_radius = 2 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 2 support_material_interface_pattern = rectilinear support_material_interface_spacing = 0.2 support_material_interface_speed = 30 support_material_pattern = rectilinear-grid support_material_spacing = 2.5 support_material_speed = 45 support_material_style = organic support_material_synchronize_layers = 1 support_material_threshold = 45 support_material_with_sheath = 1 support_material_xy_spacing = 60% support_tree_angle = 40 support_tree_angle_slow = 25 support_tree_branch_diameter = 2 support_tree_branch_diameter_angle = 5 support_tree_branch_diameter_double_wall = 3 support_tree_branch_distance = 1 support_tree_tip_diameter = 0.8 support_tree_top_rate = 15% thick_bridges = 1 thin_walls = 1 top_fill_pattern = concentric top_infill_extrusion_width = 0 top_solid_infill_acceleration = 0 top_solid_infill_speed = 30 top_solid_layers = 1 top_solid_min_thickness = 1 travel_acceleration = 0 travel_speed = 60 travel_speed_z = 0 wall_distribution_count = 1 wall_transition_angle = 10 wall_transition_filter_deviation = 25% wall_transition_length = 100% wipe_tower = 1 wipe_tower_bridging = 15 wipe_tower_brim_width = 2 wipe_tower_cone_angle = 0 wipe_tower_extra_spacing = 100% wipe_tower_extruder = 0 wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 40 wipe_tower_x = 60.7741 wipe_tower_y = 33.9468 xy_size_compensation = 0 [print:Quality @4Max Pro 2.0] arc_fitting = disabled avoid_crossing_curled_overhangs = 0 avoid_crossing_perimeters = 0 avoid_crossing_perimeters_max_detour = 0 bottom_fill_pattern = alignedrectilinear bottom_solid_layers = 3 bottom_solid_min_thickness = 1.2 bridge_acceleration = 300 bridge_angle = 0 bridge_flow_ratio = 0.62 bridge_speed = 30 brim_separation = 0 brim_type = outer_only brim_width = 4 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = complete_objects = 0 default_acceleration = 500 dont_support_bridges = 1 draft_shield = disabled elefant_foot_compensation = 0.25 enable_dynamic_overhang_speeds = 0 external_perimeter_acceleration = 0 external_perimeter_extrusion_width = 0.45 external_perimeter_speed = 70% external_perimeters_first = 0 extra_perimeters = 1 extra_perimeters_on_overhangs = 0 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.4 fill_angle = 45 fill_density = 20% fill_pattern = gyroid first_layer_acceleration = 300 first_layer_acceleration_over_raft = 0 first_layer_extrusion_width = 0.65 first_layer_height = 0.26 first_layer_speed = 20 first_layer_speed_over_raft = 30 fuzzy_skin = none fuzzy_skin_point_dist = 0.8 fuzzy_skin_thickness = 0.3 gap_fill_enabled = 1 gap_fill_speed = 40 gcode_comments = 0 gcode_label_objects = disabled gcode_resolution = 0.0125 gcode_substitutions = infill_acceleration = 600 infill_anchor = 400% infill_anchor_max = 50 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.6 infill_first = 0 infill_overlap = 23% infill_speed = 45 inherits = interface_shells = 0 ironing = 0 ironing_flowrate = 15% ironing_spacing = 0.1 ironing_speed = 15 ironing_type = top layer_height = 0.2 max_print_speed = 50 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_bead_width = 85% min_feature_size = 25% min_skirt_length = 0 mmu_segmented_region_interlocking_depth = 0 mmu_segmented_region_max_width = 0 notes = config v7 from hartrusion.com only_retract_when_crossing_perimeters = 0 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhang_speed_0 = 15 overhang_speed_1 = 15 overhang_speed_2 = 20 overhang_speed_3 = 25 overhangs = 1 perimeter_acceleration = 500 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_generator = arachne perimeter_speed = 50 perimeters = 4 post_process = print_settings_id = raft_contact_distance = 0.1 raft_expansion = 1.5 raft_first_layer_density = 90% raft_first_layer_expansion = 3 raft_layers = 0 resolution = 0 seam_position = aligned single_extruder_multi_material_priming = 1 skirt_distance = 7 skirt_height = 1 skirts = 2 slice_closing_radius = 0.05 slicing_mode = regular small_perimeter_speed = 40% solid_infill_acceleration = 0 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 88.8% spiral_vase = 0 staggered_inner_seams = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_auto = 1 support_material_bottom_contact_distance = 0 support_material_bottom_interface_layers = -1 support_material_buildplate_only = 1 support_material_closing_radius = 2 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0.45 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 2 support_material_interface_pattern = rectilinear support_material_interface_spacing = 0.2 support_material_interface_speed = 30 support_material_pattern = rectilinear-grid support_material_spacing = 2.5 support_material_speed = 45 support_material_style = grid support_material_synchronize_layers = 0 support_material_threshold = 45 support_material_with_sheath = 1 support_material_xy_spacing = 50% support_tree_angle = 40 support_tree_angle_slow = 25 support_tree_branch_diameter = 2 support_tree_branch_diameter_angle = 5 support_tree_branch_diameter_double_wall = 3 support_tree_branch_distance = 1 support_tree_tip_diameter = 0.8 support_tree_top_rate = 15% thick_bridges = 1 thin_walls = 1 top_fill_pattern = alignedrectilinear top_infill_extrusion_width = 0 top_solid_infill_acceleration = 0 top_solid_infill_speed = 65% top_solid_layers = 3 top_solid_min_thickness = 1.2 travel_acceleration = 0 travel_speed = 75 travel_speed_z = 0 wall_distribution_count = 1 wall_transition_angle = 10 wall_transition_filter_deviation = 25% wall_transition_length = 100% wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_brim_width = 2 wipe_tower_cone_angle = 0 wipe_tower_extra_spacing = 100% wipe_tower_extruder = 0 wipe_tower_no_sparse_layers = 0 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 180 wipe_tower_y = 140 xy_size_compensation = 0 [filament:Anycubic PLA CPL020 White @4Max Pro 2.0] bed_temperature = 60 bridge_fan_speed = 100 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 4 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 30 filament_colour = #FFFFFF filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 25 filament_density = 1.156 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 4.5 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\n195-220 deg C wirtten on spool thingy" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = 2 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = 0.2 filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 500 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 60 first_layer_temperature = 210 full_fan_speed_layer = 8 idle_temperature = nil inherits = max_fan_speed = 80 min_fan_speed = 45 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 15 start_filament_gcode = "; Filament gcode\n" temperature = 197 [filament:Anycubic PLA D0163 Grey @4Max Pro 2.0] bed_temperature = 60 bridge_fan_speed = 100 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 4 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 30 filament_colour = #808080 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 25 filament_density = 1.156 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\n190-230 deg C written on box, 200-230 deg C wirtten on spool thingy" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = 2.7 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = 0.2 filament_retract_restart_extra_toolchange = nil filament_retract_speed = 45 filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 1000 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 60 first_layer_temperature = 215 full_fan_speed_layer = 10 idle_temperature = nil inherits = max_fan_speed = 60 min_fan_speed = 35 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 15 start_filament_gcode = "; Filament gcode\n" temperature = 207 [filament:Factory ABS @4Max Pro 2.0] bed_temperature = 100 bridge_fan_speed = 0 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 3 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #800000 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 0 filament_density = 0 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = nil filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 0 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = ABS filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 100 first_layer_temperature = 245 full_fan_speed_layer = 0 idle_temperature = nil inherits = max_fan_speed = 0 min_fan_speed = 0 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 5 start_filament_gcode = "; Filament gcode\n" temperature = 245 [filament:Factory PLA @4Max Pro 2.0] bed_temperature = 60 bridge_fan_speed = 100 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 2 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 10 filament_colour = #CCC5BD filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 0 filament_density = 0 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nSuggested temps in printer manual: 205 deg C with bed temp 60 deg C " filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = 0 filament_retract_length = 2.5 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = 30 filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 0 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 60 first_layer_temperature = 205 full_fan_speed_layer = 10 idle_temperature = nil inherits = max_fan_speed = 100 min_fan_speed = 10 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 5 start_filament_gcode = "; Filament gcode\n" temperature = 205 [filament:Factory TPU @4Max Pro 2.0] bed_temperature = 60 bridge_fan_speed = 0 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 3 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #211AB5 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 0 filament_density = 1.19 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nmax4 manual: print head 215, bed 60" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = 0 filament_retract_length = 2.5 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = 30 filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 0 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 60 first_layer_temperature = 215 full_fan_speed_layer = 0 idle_temperature = nil inherits = max_fan_speed = 0 min_fan_speed = 0 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 5 start_filament_gcode = "; Filament gcode\n" temperature = 215 [filament:FilaFlex 82A @4Max Pro 2.0] bed_temperature = 30 bridge_fan_speed = 80 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 5 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \n; G91 ; relative positioning\n; G1 E-5 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1.113 fan_always_on = 1 fan_below_layer_time = 45 filament_colour = #2B3033 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 69.8 filament_density = 1.12 filament_deretract_speed = 45 filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 1.26 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nto avoid oozing, use the avoid crossing perimeters option" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = 1 filament_retract_before_wipe = nil filament_retract_layer_change = 1 filament_retract_length = 8.5 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = 0.5 filament_retract_restart_extra_toolchange = nil filament_retract_speed = 60 filament_settings_id = "FilaFlex 82A @4Max Pro 2.0" filament_soluble = 0 filament_spool_weight = 500 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = TPU filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 40 first_layer_temperature = 235 full_fan_speed_layer = 10 idle_temperature = nil inherits = max_fan_speed = 45 min_fan_speed = 25 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 10 start_filament_gcode = "; Filament gcode\n" temperature = 234 [filament:FilaFlex Pro 60A @4Max Pro 2.0] bed_temperature = 30 bridge_fan_speed = 80 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 2 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \n; G91 ; relative positioning\n; G1 E-5 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1.13 fan_always_on = 1 fan_below_layer_time = 45 filament_colour = #31443F filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 99.8 filament_density = 1.12 filament_deretract_speed = 25 filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 1.1 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nto avoid oozing, use the avoid crossing perimeters option" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = 1 filament_retract_before_wipe = nil filament_retract_layer_change = 1 filament_retract_length = 8.5 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = 0.3 filament_retract_restart_extra_toolchange = nil filament_retract_speed = 30 filament_settings_id = "Filaflex 82A @4Max Pro 2.0" filament_soluble = 0 filament_spool_weight = 500 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = TPU filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 40 first_layer_temperature = 222 full_fan_speed_layer = 4 idle_temperature = nil inherits = max_fan_speed = 50 min_fan_speed = 35 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 10 start_filament_gcode = "; Filament gcode\n" temperature = 218 [filament:Mvs ABS @4Max Pro 2.0] bed_temperature = 100 bridge_fan_speed = 0 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 3 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #C6E100 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 24 filament_density = 1.04 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nfilament bought from super-filament.de on ebay, probably brand is MVS\nrecommended nozzle: 190 to 230 deg C, bed 80 to 100 deg C" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = nil filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 1000 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = ABS filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 100 first_layer_temperature = 245 full_fan_speed_layer = 0 idle_temperature = nil inherits = max_fan_speed = 0 min_fan_speed = 0 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 25 start_filament_gcode = "; Filament gcode\n" temperature = 240 [filament:PLA] bed_temperature = 60 bridge_fan_speed = 100 compatible_printers = compatible_printers_condition = printer_notes!~/.*NO_TEMPLATES.*/ and printer_notes!~/.*PRINTER_VENDOR_TRILAB.*/ and printer_notes!~/.*PRINTER_MODEL_MK4IS.*/ and ! (printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and num_extruders>1) compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 4 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 100 filament_colour = #0080FF filament_cooling_final_speed = 0 filament_cooling_initial_speed = 0 filament_cooling_moves = 0 filament_cost = 27.82 filament_density = 1.24 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 0 filament_loading_speed_start = 0 filament_max_volumetric_speed = 15 filament_minimal_purge_on_wipe_tower = 0 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "" filament_ramming_parameters = "130 120 2.70968 2.93548 3.32258 3.83871 4.58065 5.54839 6.51613 7.35484 7.93548 8.16129| 0.05 2.66451 0.45 3.05805 0.95 4.05807 1.45 5.97742 1.95 7.69999 2.45 8.1936 2.95 11.342 3.45 11.4065 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = nil filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 230 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 0 filament_unloading_speed_start = 0 filament_vendor = Made for Prusa filament_wipe = nil first_layer_bed_temperature = 60 first_layer_temperature = 230 full_fan_speed_layer = 8 idle_temperature = 70 inherits = Prusa PLA @Template max_fan_speed = 55 min_fan_speed = 33 min_print_speed = 15 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 8 start_filament_gcode = "; Filament gcode\n" temperature = 210 [filament:PolyFlex TPU95 @4Max Pro 2.0] bed_temperature = 45 bridge_fan_speed = 80 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 5 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-5 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1.04 fan_always_on = 1 fan_below_layer_time = 45 filament_colour = #FD7D2F filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 67.7 filament_density = 1.22 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 1.65 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = 1 filament_retract_before_wipe = nil filament_retract_layer_change = 1 filament_retract_length = 4 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = 0.1 filament_retract_restart_extra_toolchange = nil filament_retract_speed = 60 filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 750 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = TPU filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 55 first_layer_temperature = 215 full_fan_speed_layer = 10 idle_temperature = nil inherits = max_fan_speed = 50 min_fan_speed = 25 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 10 start_filament_gcode = "; Filament gcode\n" temperature = 217 [filament:PolyMide CoPA @4Max Pro 2.0] bed_temperature = 40 bridge_fan_speed = 30 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 3 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;M104 S0 ; turn off extruder heating\n;G28 X0 Y0 ; goto x and y home\n;M140 S70 ; set bed temp to 70 degrees to anneal the print for 2 hours inside the printer\n;M117 annealing\n;G4 S54000 ; wait 2 hrs\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 60 filament_colour = #D6D894 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 92.67 filament_density = 1.12 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 2.4 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nto avoid edge curling, increase layer height" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = nil filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 750 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = NYLON filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 50 first_layer_temperature = 255 full_fan_speed_layer = 6 idle_temperature = nil inherits = max_fan_speed = 25 min_fan_speed = 20 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 40 start_filament_gcode = "; Filament gcode\n" temperature = 253 [filament:RedPLA] bed_temperature = 60 bridge_fan_speed = 100 compatible_printers = compatible_printers_condition = printer_notes!~/.*NO_TEMPLATES.*/ and printer_notes!~/.*PRINTER_VENDOR_TRILAB.*/ and printer_notes!~/.*PRINTER_MODEL_MK4IS.*/ and ! (printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and num_extruders>1) compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 4 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 100 filament_colour = #FF0000 filament_cooling_final_speed = 0 filament_cooling_initial_speed = 0 filament_cooling_moves = 0 filament_cost = 27.82 filament_density = 1.24 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 0 filament_loading_speed_start = 0 filament_max_volumetric_speed = 15 filament_minimal_purge_on_wipe_tower = 0 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "" filament_ramming_parameters = "130 120 2.70968 2.93548 3.32258 3.83871 4.58065 5.54839 6.51613 7.35484 7.93548 8.16129| 0.05 2.66451 0.45 3.05805 0.95 4.05807 1.45 5.97742 1.95 7.69999 2.45 8.1936 2.95 11.342 3.45 11.4065 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = nil filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 230 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 0 filament_unloading_speed_start = 0 filament_vendor = Made for Prusa filament_wipe = nil first_layer_bed_temperature = 60 first_layer_temperature = 230 full_fan_speed_layer = 8 idle_temperature = 70 inherits = Prusa PLA @Template max_fan_speed = 55 min_fan_speed = 33 min_print_speed = 15 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 8 start_filament_gcode = "; Filament gcode\n" temperature = 210 [filament:filatech HIPS @4Max Pro 2.0] bed_temperature = 110 bridge_fan_speed = 50 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 2 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-3 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 45 filament_colour = #EEEEE8 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 25 filament_density = 1.156 filament_deretract_speed = nil filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = nil filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = nil filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 1000 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = HIPS filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 105 first_layer_temperature = 225 full_fan_speed_layer = 10 idle_temperature = nil inherits = max_fan_speed = 45 min_fan_speed = 20 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 10 start_filament_gcode = "; Filament gcode\n" temperature = 220 [filament:yourDroid TPU @4Max Pro 2.0] bed_temperature = 45 bridge_fan_speed = 45 compatible_printers = "Anycubic 4Max Pro 2.0" compatible_printers_condition = compatible_prints = compatible_prints_condition = cooling = 0 disable_fan_first_layers = 5 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode \nG91 ; relative positioning\nG1 E-5 F300 ; retract the filament to release pressure\n;END gcode for filament\n" extrusion_multiplier = 1.13 fan_always_on = 1 fan_below_layer_time = 45 filament_colour = #1FC216 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 36.9 filament_density = 1.18 filament_deretract_speed = 20 filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 1.2 filament_minimal_purge_on_wipe_tower = 15 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 10 filament_multitool_ramming_volume = 10 filament_notes = "config v7 from hartrusion.com\nseller description: printing temperature: 205-230, plattform 0-70\nupdated with v5" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = nil filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = 2 filament_retract_length_toolchange = nil filament_retract_lift = nil filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = 0.3 filament_retract_restart_extra_toolchange = nil filament_retract_speed = 50 filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 500 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = nil filament_travel_ramping_lift = nil filament_travel_slope = nil filament_type = TPU filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = (Unknown) filament_wipe = nil first_layer_bed_temperature = 50 first_layer_temperature = 210 full_fan_speed_layer = 15 idle_temperature = nil inherits = max_fan_speed = 100 min_fan_speed = 10 min_print_speed = 10 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 10 start_filament_gcode = "; Filament gcode\n" temperature = 205 [printer:AnycubicPalette3Pro] autoemit_temperature_commands = 1 bed_custom_model = bed_custom_texture = bed_shape = 0x0,270x0,270x210,0x210 before_layer_gcode = ;BEFORE_LAYER_CHANGE G92 E0 between_objects_gcode = binary_gcode = 0 color_change_gcode = M600 cooling_tube_length = 0 cooling_tube_retraction = 0 default_filament_profile = "Generic PLA @4Max Pro 2.0" default_print_profile = 0.20mm Quality @4Max Pro 2.0 deretract_speed = 0,25,25,25,25,25,25,25 end_gcode = M104 S0 ; turn off extruder heating\nM140 S0 ; turn off bed heating\nM107 ; turn off fans\nG91 ; relative positioning\nG0 Z+0.5 ; move Z up a tiny bit\nG90 ; absolute positioning\nG0 X135 Y105 F{machine_max_feedrate_x[0]*60} ; move extruder to center position\nG0 Z190.5 F{machine_max_feedrate_z[0]*60} ; lower the plattform to Z min\nM84 ; steppers off\nM106 S255 ; cool down part cooling fan nozzle\nG4 P30 ; for about 30 seconds\nM107 ; turn off fan\nG90 ; absolute positioning\nM300 P300 S4000 ; make some beep that print is finished\n extra_loading_move = 0 extruder_colour = #0080FF;#FF0000;;;;;; extruder_offset = 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0 gcode_flavor = marlin high_current_on_filament_swap = 0 host_type = prusalink inherits = Anycubic 4Max Pro 2.0 layer_gcode = ;AFTER_LAYER_CHANGE\n;LAYER [layer_num]\n;LAYERHEIGHT [layer_z]\nG92 E0 machine_limits_usage = time_estimate_only machine_max_acceleration_e = 5000 machine_max_acceleration_extruding = 1250 machine_max_acceleration_retracting = 1250 machine_max_acceleration_travel = 1500 machine_max_acceleration_x = 900 machine_max_acceleration_y = 900 machine_max_acceleration_z = 100 machine_max_feedrate_e = 120 machine_max_feedrate_x = 200 machine_max_feedrate_y = 200 machine_max_feedrate_z = 16 machine_max_jerk_e = 5 machine_max_jerk_x = 6 machine_max_jerk_y = 6 machine_max_jerk_z = 0.2 machine_min_extruding_rate = 0 machine_min_travel_rate = 0 max_layer_height = 0.2,0.2,0.2,0.2,0.2,0.2,0.2,0.2 max_print_height = 190 min_layer_height = 0.2,0.2,0.2,0.2,0.2,0.2,0.2,0.2 nozzle_diameter = 0.4,0.4,0.4,0.4,0.4,0.4,0.4,0.4 parking_pos_retraction = 0 pause_print_gcode = M601 print_host = printer_model = 4MAXPRO20 printer_notes = printer_settings_id = printer_technology = FFF printer_variant = 0.4 printer_vendor = printhost_apikey = printhost_cafile = remaining_times = 0 retract_before_travel = 1,2,2,2,2,2,2,2 retract_before_wipe = 0%,0%,0%,0%,0%,0%,0%,0% retract_layer_change = 1,1,1,1,1,1,1,1 retract_length = 0.8,2.5,2.5,2.5,2.5,2.5,2.5,2.5 retract_length_toolchange = 10,10,10,10,10,10,10,10 retract_lift = 0.05,0.05,0.05,0.05,0.05,0.05,0.05,0.05 retract_lift_above = 0,0,0,0,0,0,0,0 retract_lift_below = 0,0,0,0,0,0,0,0 retract_restart_extra = 0,0,0,0,0,0,0,0 retract_restart_extra_toolchange = 0,0,0,0,0,0,0,0 retract_speed = 35,35,35,35,35,35,35,35 silent_mode = 0 single_extruder_multi_material = 1 start_gcode = G21 ; metric values\nG90 ; absolute positioning\nM82 ; set extruder to absolute mode\nM140 S[first_layer_bed_temperature] ; set bed temp\nG28 X0 Y0 ; home X and Y\nG28 Z0 ; home Z\nG1 Z30 F{machine_max_feedrate_z[0]*60} ; move Z a bit down to not blow on the bed edge while heating\nG1 X10 F3900 ; let some space on x to prevent the filament cooling exhaust from beeing blocked by the servo motor\nM190 S[first_layer_bed_temperature] ; wait for bed temp\nM104 S[first_layer_temperature] ; set extruder temp\nM106 S80 ; turn on fan to prevent air nozzle melt while heating up\nM109 S[first_layer_temperature] ; wait for extruder temp\nM107 ; start with the fan off\nG28 X0 ; goto X home again\nG92 E0 ; zero the extruded length\nG1 Z0.2 F360 ; move plattform upwards\n; extrude material next to the plattform (comment or remove following lines to disable)\nG1 F180 E20 ; extrude some material next to the plattform\nG92 E0 ; zero the extruded length\nG1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract\nG92 E0 ; zero the extruded length again\nG1 X5 F3900 ; move sideways to get rid of that string\nG1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters\nG92 E0 ; zero the extruded length again\n; draw intro line (comment or remove following lines to disable)\nG1 X30 E5 F700 ; draw intro line\nG92 E0 ; zero the extruded length\nG1 E-[retract_length] F{retract_speed[0]*60} ; do a filament retract\nG1 X40 Z2.0 ; move away from the introline\nG92 E0 ; zero the extruded length again\nG1 E[retract_length] F{retract_speed[0]*60} ; do a filament deretract with retract parameters\n; end of intro line code\nG1 F100 ; from sample code dunno why its here\nM117 Printing...\n\n;P2PP PALETTE3_PRO\n;P2PP PALETTE3_PRO\n;P2PP PRINTERPROFILE=c93e2561cf74459fa3ca7a797ad16066\n\n;P2PP SPLICEOFFSET=40\n\n;P2PP MINSTARTSPLICE=130\n;P2PP MINSPLICE=90\n\n;P2PP EXTRAENDFILAMENT=150\n;P2PP LINEARPINGLENGTH=350\n\n;P2PP FILAMENTOVERRIDE=RedPLA\n;P2PP MATERIAL_PLA_PLA_2_1_2\n;P2PP MATERIAL_PLA_RedPLA_2_1_2\n;P2PP MATERIAL_RedPLA_PLA_2_1_2\n\n;set P2PP ABSOLUTEEXTRUDER\n;P2PP PURGETOWERDELTA=0\n\n;P2PP FULLPURGEREDUCTION \n;P2PP WIPEFEEDRATE=3000\n;P2PP AUTOADDPURGE \n\n;P2PP TEMPERATURECONTROL\n\nG5\n template_custom_gcode = thumbnails = 640x480/PNG thumbnails_format = PNG toolchange_gcode = travel_lift_before_obstacle = 0,0,0,0,0,0,0,0 travel_max_lift = 0,0,0,0,0,0,0,0 travel_ramping_lift = 0,0,0,0,0,0,0,0 travel_slope = 0,0,0,0,0,0,0,0 use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 variable_layer_height = 0 wipe = 1,0,0,0,0,0,0,0 z_offset = 0 [presets] print = MosaicPalette sla_print = sla_material = printer = AnycubicPalette3Pro filament = PLA filament_1 = RedPLA filament_2 = PLA filament_3 = PLA filament_4 = RedPLA filament_5 = RedPLA filament_6 = RedPLA filament_7 = RedPLA physical_printer =
Best Answer by Neophyl:
First of all welcome. Secondly can you not post long lists that are impossible to go through, if you want to post that info the simplest way is to save a project from PRUSA slicer (file>save project as)and the 3mf saved will contain a copy of all 3 profiles in use as well as any models and modifiers etc. The only thing to remember is that all files attached should be zipped up or the forum here will just silently not attach them. No warnings.
As to your specific issue, there is no issue. It is deliberately programmed to do that. Someone else very recently also asked this same question. It’s currently on the second page of this very sub forum, https://forum.prusa3d.com/forum/prusaslicer/finishing-wipe-tower-in-mid-air/
RE: what is wrong with my bundle
That's just the final purge at the end of the print.
As BaconFase said. And please, don't include pages of configs that are hard to parse. Much better is to upload a zipped 3mf project file saved from Prusaslicer, which contains all your settings and makes it much easier to see if anything is suspicious.
