What is M73 Q17 S43 g-code command?
Alex
 Alex
(@alex-3)
I know that M73 P19 means "Set completion progress to 19%", and I suspect that M73 R42 means "Set remaining time to 42 minutes", but what is M73 Q17 S43? I can't find description of such syntax.
(The command is seen in .gcode files produced by PrusaSlicer)
Best Answer by Neophyl:
Not 100% certain but I think one set is for when the printer is in normal mode and the second set are used when the printer is in Stealth mode. As In R=Regular and S=Stealth
Questa discussione è stata modificata 6 years fa da Alex
Postato : 12/11/2019 11:33 am
RE: What is M73 Q17 S43 g-code command?
Postato : 12/11/2019 1:03 pm
1 persone hanno apprezzato
Alex
 Alex
(@alex-3)
@neophyl Yeah, I can confirm this. I have looked inside MK3S firmware and have found this:
case 73: //M73 show percent done and time remaining
if(code_seen('P')) print_percent_done_normal = code_value();
if(code_seen('R')) print_time_remaining_normal = code_value();
if(code_seen('Q')) print_percent_done_silent = code_value();
if(code_seen('S')) print_time_remaining_silent = code_value();
const char* _msg_mode_done_remain = _N("%S MODE: Percent done: %d; print time remaining in mins: %d\n");
printf_P(_msg_mode_done_remain, _N("NORMAL"), int(print_percent_done_normal), print_time_remaining_normal);
printf_P(_msg_mode_done_remain, _N("SILENT"), int(print_percent_done_silent), print_time_remaining_silent);
break;
Thanks for the idea.
Questo post è stato modificato 6 years fa 2 tempo da Alex
Postato : 12/11/2019 1:11 pm
