Weird perimeter printing
goldensuneur
(@goldensuneur)
Miembro
I noticed that for the first few layers PrusaSlicer is adding a lot of small outside perimeters and a lot of travel in between instead of extruding two continuous perimeters like it does a few layers above. I'd like to always have continuous extrusion for better surface finish of the print and I cannot switch to vase mode because I need 2 wall thickness for increased opacity. It it this model printed on a core one+ and all defaults profiles show the same behavior. Do you know which settings should I tweak to get rid of these small perimeters in the first layers ?
Many small perimeters causing a lot of travels and irregularities in the print:
Then a continuous extrusion:
Respondido : 11/05/2026 4:58 pm
