Weird perimeter printing
goldensuneur
(@goldensuneur)
I noticed that for the first few layers PrusaSlicer is adding a lot of small outside perimeters and a lot of travel in between instead of extruding two continuous perimeters like it does a few layers above. I'd like to always have continuous extrusion for better surface finish of the print and I cannot switch to vase mode because I need 2 wall thickness for increased opacity. It it this model printed on a core one+ and all defaults profiles show the same behavior. Do you know which settings should I tweak to get rid of these small perimeters in the first layers ?
Many small perimeters causing a lot of travels and irregularities in the print:
Then a continuous extrusion:
Posted : 11/05/2026 4:58 pm
_KaszpiR_
(@_kaszpir_)
RE: Weird perimeter printing
I assume you try to print `inside.stl` model rotated 180 degrees to the original source.
With PrusaSlicer 2.9.4 I see no issues with Core One L with 0.20mm Structural profile.
Please provide more details about the software used and zip .3mf file and attach as 'Add Media'.
Posted : 13/05/2026 10:31 pm
_KaszpiR_
(@_kaszpir_)
goldensuneur
(@goldensuneur)
Thank you, my bad, I forgot the say it's the outside.stl model that has the issue. And yes, printed rotated 180° and with PrusaSlicer 2.9.4.
Here is the project, you'll see the issue between layers 7 and 35.
Posted : 14/05/2026 6:31 am
