Weird pathing for hexagonal surface / printing issue?
rrobe53
(@rrobe53)
So I'm trying to print this Raspberry Pi Case, https://www.prusaprinters.org/prints/8609-snapcase-for-raspberry-pi4b, and the shape is giving me fits. When slicing it in PrusaSlicer I noticed it's jumping around with the pathing for the internal hexagonal shape.
I'm using AmazonBasics PETG and I haven't really had a problem with it before but I can't seem to get it to print this. The failures seem come with it jumping around for the hexagonal shape.
This is one of the worse failures, and I've gotten better / worse results playing with the Z-height, trying the textured sheet, changing bed temperature, but there's always some measure of failure. It seems to print fine when it's not jumping across the hexagons, but the wide jumps seems to cause a problem. Is there an option to prevent those jumps that I'm just struggling to find?
Napsal : 06/07/2021 1:49 pm
RE: Weird pathing for hexagonal surface / printing issue?
It's hard to tell from the picture, but looking at the corners, it looks like your Live-Z setting is too low (too negative). The nozzle is low enough to gouge the top surfaces. This can easily result in a build-up of filament on the nozzle, which can easily snag previously printed layers and create the mess you're seeing. The same can happen if Live-Z is too high (not negative enough) as filament doesn't adhere to the bed, curls up, and sticks to the nozzle or hotend. PETG is particularly tricky as it tends to want to stick to whatever's hottest nearby, which can be the nozzle if bed adhesion isn't good. You're after that "Goldilocks zone" where the nozzle is low enough to adhere well, but not drag the nozzle. PETG tends to like less "squish" than PLA.
If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the onboard routine and much easier to make mid-print adjustments accurately with. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines on the PEI surface without dislodging them.  Then start lowering (more negative) the level until there are no gaps between layers. You should not be able to peel the lines apart after printing, but the top should be regular.
If you've got your Live-Z and bed properly cleaned for good 1st layer adhesion, that pattern shouldn't cause any problems.
Napsal : 06/07/2021 4:46 pm
rrobe53
(@rrobe53)
So from the bottom right to the top left is the direction it printed, and I noticed that it looked like it was sticking quite easily so I moved it less and less negative as the print went on (0.1 increments) and noticed it was as less desirable texture, but still sticking to the bed.
After it finished printing this is the view from peeling it up, and all layers essentially separated themselves upon lifting.
When I was setting up the textured sheet I noticed that if it wasn't more negative it got less of the textured effect on the bottom.
This post was modified před 5 years by rrobe53
Napsal : 06/07/2021 5:20 pm
rrobe53
(@rrobe53)
So I'm trying to print this now, a small little thing that I'll actually use, rather than the whole Raspberry Pi case that takes a minute to fail. https://www.prusaprinters.org/prints/2016-prusa-i3-mk-filament-guide-clipon
Starting with where I left the grid it was a complete failure, -0.8
So I decreased the Z-Height to -0.9
And then -1
And it feels like it's trending in the right direction. However, this is further than was required in the square so I'm not sure if I'm doing something wrong there or not understanding what you mean by having it at the "just starting to stick" point.
Napsal : 06/07/2021 5:54 pm
Argh. I hate trying to interpret pics. It looked rough in the 1st, but if the square is falling apart, you are definitely too high. Being high at the start is actually good. Bring it down 0.08mm and work down in 0.02mm increments until the surface starts to even out. When you've got it right, the square should peel up and not pull apart easily. I've got some illustrated notes on using Live-Z herethat might be helpful.
Napsal : 06/07/2021 6:03 pm
1 lidem se líbí
rrobe53
(@rrobe53)
So you think I should be lower than I was when I started out? Sorry about taking a while to respond, I'm responding pretty quickly but it appears I got flagged for moderation since I have a new account.
Napsal : 06/07/2021 6:05 pm
I may have misread your 1st picture. Print the 75x75mm square and take a pic and post that. Try to get a clear enough pic to show the extrusions clearly.
  • If the angled lines have gaps between them and there are gaps between the angled extrusions and perimeters, you're a bit high. Move down (make more negative) your Live-Z by 0.04-0.06mm gaps until they start closing up, then lower by 0.02mm until it looks even.
  • If the angled lines are rough, the nozzle is probably dragging. Raise your Live-Z (make less negative) by 0.06mm and increase by 0.02mm until it smooths out.
You're better off starting a bit high (the gaps are easy to spot) and move down as the gaps are easy to spot.
If you have no luck, take your PEI sheet to the kitchen sink and use some Dawn dish soap (or equivalent) on it. Nothing with hand softeners. Scrub it with a plain paper towel under hot water, rinse it, and dry it with another plain paper towel. Dry it but do not touch the print area. Don't do anything else and try Live-Z adjustment again.
If you are printing PLA, use the SMOOTH PEI sheet. If printing PETG, use the textured PEI sheet. Be aware that each has very different Live-Z requirements due to varying thickness.
Napsal : 06/07/2021 6:51 pm
rrobe53
(@rrobe53)
I read through your site and I really appreciate it, seems real clear and I think I'm moving in the right direction. Here's the Z-Height that I had in my original post, which is what I'd set using the original method -1.350, for the entire thing.
Some slight gaps in the top left there.
I do tend to prefer the textured sheet and have been using it for PETG, but my original post I was just trying a bunch of different things to try to get it to work. I haven't scrubbed it with Dawn though, is that potentially enough to cause what I was seeing with the original hexagonal shapes?
Napsal : 06/07/2021 6:56 pm
Posted by: @rrobe53
Those pics look very close. You can try going a bit lower to see if the little dots along the edges close up. When you peel it off, it should be a solid sheet.
Possibly. If your bed adhesion isn't good, parts tend to lift easily which can cause the nozzle to snag.
Mastering the PEI takes a bit, but it's worth it not to have to use goop on your bed, brims, or (shudder) rafts.
Napsal : 06/07/2021 7:59 pm
rrobe53
(@rrobe53)
So I dunno. I changed out for the orange filament so it was easier to see while printing the test. The square looks good to me, got rid of the circles in the corner.
Yet this is still a failure... Same Z-Axis, same temperatures and layer height as the square.
Napsal : 06/07/2021 10:38 pm
If that's PLA, try the SMOOTH PEI sheet. If it's PETG, give the textured sheet a good wash.
It is possible to get a bad textured sheet. I had one that was a complete write-off. You can print PETG just fine on the smooth PEI, but be sure to put some sort of separator agent (Windex is recommended) before printing higher temps on it.
Napsal : 07/07/2021 2:02 am
rrobe53
(@rrobe53)
Aside from the initial this has all been on the textured sheet and has all been PETG. I've been experimenting more, setting my bed to a lower temperature, which seems counterintuitive but seems to be having positive effects.
Napsal : 07/07/2021 2:16 am
Posted by: @rrobe53
I'd normally print a test layer out of solidarity, but unfortunately, my Mk3 is out of action awaiting parts. I did have a bad experience with a textured sheet, so would try PETG on the smooth PEI (with a spritz of Windex) to test. Other than that, it sounds like you're making progress. PETG should stick firmly for your 1st layer just like PLA, so the same basic procedures apply. Good luck with it!
Napsal : 07/07/2021 1:34 pm
