View Filament Use Up To X Layer?
secv
 secv
(@secv)
Is there a function to view filament use up to a certain layer? For example, g of filament used from layer Zero to layer 100. Currently I use the cut tool to split a model then preview the entire sliced model.
Napsal : 24/03/2023 7:51 pm
RE: View Filament Use Up To X Layer?
Not directly no.  Theres a 'workaround' though.  You can insert a colour change at the layer you want and then slice.  It will then tell you how much of each colour the slice uses.  You can then remove the colour change for the proper slice.
Napsal : 24/03/2023 8:41 pm
R&D se líbí
