Very strange Organic Supports overhangs detection
Hello everyone!
I use organic supports all the time, but paint it before with "Paint-on supports" tool. Recently rebuild my extruder and start to recalibrate printer and settings. I've found this with automatic generated supports:
1) Overhanged supports over the threshold 35% with "Snug":
2) Similar Overhangs but with Organic:
On GitHub I find some branches with problem and info that this problem was solved:
https://github.com/prusa3d/PrusaSlicer/issues/9681
https://github.com/prusa3d/PrusaSlicer/issues/9459
https://github.com/prusa3d/PrusaSlicer/issues/9556
But on practice it's not or I can't understand something... Maybe some settings must be changed?
I download older version 2.6.0-alpha4 and with similar settings Organic Supports was fixed! It worked before as expected!
Why this bug is come back with newer version!?
RE: Very strange Organic Supports overhangs detection
Please report it on GitHub with examples.
I personally use 25 degrees for snug, as if the logic was inverted or something
Thanks for your advice!
I create an Issue Report: https://github.com/prusa3d/PrusaSlicer/issues/12104
I'm printing big objects like my custom masks or helmets and Snug not acceptable for me... I've tried to use Cura Tree supports but they not so good and use more filament for printing. I hope this bug will be fixed soon, because I've find out some systematic Issue when write a post for GitHub 😥
