Vase mode and speed issues
jmayniac
(@jmayniac)
If set vase mode in PrusaSlicer and try to print exterior perimeters at 100mm/s, the speed feature in layer view shows it will only print at 41mm/s.  No matter what speed I set over 41mm/s it will always be slowed down to 41mm/s.  I tried to print just in case and it definitely printed at 41mm/s.  Am I missing something on how this works?  This is on the latest PrusaSlicer 2.1 and an Ender 3.
Veröffentlicht : 27/11/2019 4:42 am
RE: Vase mode and speed issues
Volumetric flow will slow print speeds, and there is a cooling limit setting that also slows print speeds to keep layer print times at some minimal time. Check your filament settings.
Veröffentlicht : 28/11/2019 10:44 pm
The size of the part comes into play. If the part isn't big enough to allow the nozzle to accelerate to full speed and decelerate, speeds will be lower.
Veröffentlicht : 29/11/2019 1:04 am
ltlowe
(@ltlowe)
The slow down appears to be caused by minimum layer time. In vase mode layer changes appear a lot more frequent than if the model was sliced normally.
I disabled auto cooling on the filment tab and that gives me speeds closer to what I set for perimeters.
Veröffentlicht : 30/11/2019 3:26 am
