Variable layer height settings
[Gelöst] Variable layer height settings
NotSure
(@notsure-3)
Hello,
can I somehow set the variable layer height maximum and minimum? Now when I change the layerheight with the mousebuttons I cannot precisly set the layer height and it goes down to 0,07.
I would like a max of 0,3 and a min of 0,1. I cannot find any settings.
Thanks
Best Answer by Neophyl:
If you go to Printer Settings, under your extruder settings you can define the minimum and maximum layer heights the extruder can print.  Those limits should be respected by the variable layer height function.
You need to be in advanced mode iirc to see the settings.
Veröffentlicht : 23/11/2020 10:52 am
RE: Variable layer height settings
Veröffentlicht : 23/11/2020 12:18 pm
