UX: Support enforcers should override support mode settings.
erispe
(@erispe)
So I feel like the options: "Supports on build plate only" and "Everywhere" or "None" should be the only three options and then you add your support enforcers and blockers on top of that. The "For support enforcers only" is then redundant and would be the same as setting it to "None" and adding some enforcers. See I want I want to be able to use the "Supports on build plate only" option as a base and then include some additional supports from enforcers. But I can't do that because an Enforcer is a low ranking entity and instead I have to use "Everywhere" and block stuff or add custom enforcers everywhere. It just seems backwards. I think it would be more powerful if enforcers got to do their thing always and you can use them with the other modes.
Publié : 26/11/2020 5:27 pm
RE: UX: Support enforcers should override support mode settings.
Put your point forward on Prusa Slicer Git Hub!
the Devs will see it there.
Publié : 26/11/2020 5:54 pm
