Using Slic3r to send file to XL, but get message about Machine and filament not matching?
MileHigh3Der
(@milehigh3der)
Multi-material print worked up in Prusaslicer.  Mixes of PETG, ASA and FLEX.  Machine is loaded and knows what materials are in each.
In ASA/PETG prints, I split the difference on bed temp at 90C.
I go to send the file with the "Send to Connect", and at the top of the pop-up I get:
"No compatible printers foundPlease adjust your print settings or set up your printer to match the required settings."
I can scroll down to my XL5, and is says something about filament and machine not matching.  I press send it to the XL5, and it does, and it will print?
Why the error message, and why does it let me print it, when it says (incorrectly) that it doesn't match?
2.8.0 Prusaslicer, and latest XL5 firware from this week.
Postato : 02/09/2024 6:21 am
MileHigh3Der
(@milehigh3der)
RE: Using Slic3r to send file to XL, but get message about Machine and filament not matching?
The PrusaConnect has worked well for me for months, and now all of a sudden, it won't do anything right.  What the heck happened???  Printers going off line.
My XL5 used to be bulletproof, and now it has failed the last 5 prints due to a errors.
Postato : 02/09/2024 9:02 pm
