Using a single nozzel with the MMU2
Mouse
(@mouse)
I have a print job that only needs to use a single color filament.  Unfortunately it is large enough it needs the entire bed.  Since I have the MMU2 unit, when I place my object in PrusaSlicer the garbage box (or whatever it is really called...the reserved area to clear the nozzle for a new color to be used) takes up too much room and wont allow me to create my gcode.
Is there a way I can remove this box or tell my print to only use 1 nozzle and elimate this garbage box without having to go in and remove my filament and run it outside of the MMU2 device?
https://ibb.co/jrqv1nc
Best Answer by Mouse:
Nevermind...found an option in the Printer drop down options on the right hand side of the screen.
Postato : 07/10/2020 1:30 pm
Mouse
(@mouse)
RE: Using a single nozzel with the MMU2
Postato : 07/10/2020 1:50 pm
