Use Filament profiles for multiple printers.
RU's nephew
(@rus-nephew)
I have a number of filament profiles in Prusa Slicer. Generally, the settings in these profiles apply to all of my printers (temperature, cooling, even Advanced). Rather than reinvent the wheel over & over, I would like to have these filament profiles available to whatever printer I select. I just don't see how I can do it; at least not easily.
I saw one post that referred to a "detach" button that sounded like it decouples a filament profile from a specific printer, but I could not find such a button.
Is there an easy way to accomplish this?
Opublikowany : 11/04/2023 2:14 am
RE: Use Filament profiles for multiple printers.
First of all you need to be in either Advanced or Expert mode in the software.  The detach button is located in the Filament Settings>Dependencies tab.
Also take note of anything in the Compatible Printers and compatible print profiles condition fields too as that can also control when a filament is visible. (expert mode for these)
Opublikowany : 11/04/2023 6:18 am
