Upload to queue always failing with 400 printer offline error
James A
(@james-a)
Hi there. Up until recently, PrusaSlicer worked fine. My usual workflow is to upload to the queue, then walk over to the printer to check the bed and activating the print on the printer. I'd usually upload to queue from PrusaSlicer. I used the PrusaConnect API physical printer method. (I have a mk4 on 6.0.3.)
Lately, even when my printer is online, Prusa Slicer fails to upload, reporting that the printer is offline. If I export the file then upload it via PrusaConnect, everything works fine.
Please let me know if there is some additional debugging information that would be helpful in tracing the problem.
Napsal : 01/07/2024 1:18 am
SRSS Machine Shop
(@srss-machine-shop)
RE: Upload to queue always failing with 400 printer offline error
Did you ever get this fixed?  I have the same problem after moving our XL to another username.
Napsal : 22/04/2026 1:49 pm
