Unnecessary complex top solid infill
Gambolf
(@gambolf)
Miembro
It seems not logical to me that the slicer adds some weird movements to an all-solid top-layer between 2 objects.
I tries changing different settings now, but could not get the expected result.
I want this cause the print-quality is much better if the extruder draws the whole line instead of smaller segments.
By now i manipulate the GCODE manually, but it would be much better if the slicer can do this on it's own.
Complete object:
Bad layer between the 2 objects:
Expectation:
Example containing 3MF and GCODE for "good" and "bad" screenshot.
Respondido : 19/11/2024 1:49 pm
RE: Unnecessary complex top solid infill
This is a user to user forum.  All issues need to be reported on the appropriate github.  However this one has already been reported several times, and is a longstanding issue.
For example https://github.com/prusa3d/PrusaSlicer/issues/8818 but there are many others, most of them closed as duplicates.  In those issues one of the devs mentions that it is designed to slice this way.
Respondido : 19/11/2024 5:47 pm
