Understanding "bed_shape" values for a Delta/Circular Printer
Van Morris
(@van-morris)
This is mostly just for my own curiosity / edification, and a small project I'm working on. Can anyone make sense out of the "bed_shape" value in the .ini config file for a a delta printer? A simple 200mm radius build plate generates the following. I believe PrusaSlicer relies on this info to be correct to correctly place the object on the build plate, relative to the origin.
bed_shape = 99.6195x8.71557,98.4808x17.3648,96.5926x25.8819,93.9693x34.202,90.6308x42.2618,86.6025x50,81.9152x57.3576,76.6044x64.2788,70.7107x70.7107,64.2788x76.6044,57.3576x81.9152,50x86.6025,42.2618x90.6308,34.202x93.9693,25.8819x96.5926,17.3648x98.4808,8.71557x99.6195,6.12323e-15x100,-8.71557x99.6195,-17.3648x98.4808,-25.8819x96.5926,-34.202x93.9693,-42.2618x90.6308,-50x86.6025,-57.3576x81.9152,-64.2788x76.6044,-70.7107x70.7107,-76.6044x64.2788,-81.9152x57.3576,-86.6025x50,-90.6308x42.2618,-93.9693x34.202,-96.5926x25.8819,-98.4808x17.3648,-99.6195x8.71557,-100x1.22465e-14,-99.6195x-8.71557,-98.4808x-17.3648,-96.5926x-25.8819,-93.9693x-34.202,-90.6308x-42.2618,-86.6025x-50,-81.9152x-57.3576,-76.6044x-64.2788,-70.7107x-70.7107,-64.2788x-76.6044,-57.3576x-81.9152,-50x-86.6025,-42.2618x-90.6308,-34.202x-93.9693,-25.8819x-96.5926,-17.3648x-98.4808,-8.71557x-99.6195,-1.83697e-14x-100,8.71557x-99.6195,17.3648x-98.4808,25.8819x-96.5926,34.202x-93.9693,42.2618x-90.6308,50x-86.6025,57.3576x-81.9152,64.2788x-76.6044,70.7107x-70.7107,76.6044x-64.2788,81.9152x-57.3576,86.6025x-50,90.6308x-42.2618,93.9693x-34.202,96.5926x-25.8819,98.4808x-17.3648,99.6195x-8.71557,100x-2.44929e-14
Napsal : 02/12/2022 1:30 pm
Tim Weston
(@tim-weston)
Each pair of numbers is an X-Y co-ordinate where the X and Y values are separated by 'x'. The coordinate pairs are delineated with a ','.  The coordinates approximate a 200mm diameter circle with a series of short line segments. If you look, you will see that the coordinates run from about 100/0 to 0/100 to -100/0 to 0/-100 and back to 100/0.
I assume it has to be done that way because PrusaSlicer works with cartesian coordinates (as opposed to polar coordinates).
Cheers,
Tim
Napsal : 02/12/2022 3:29 pm
