Underextruding on first layer while rest of the layers are perfect
Pim B
(@pim-b)
Title says it all. My first layer is underextruding. Rest of my layers are perfect with extruding the right amount of filament. I noticed this after the last profile updates, so maybe it is related to that
I can't find any setting in prusa slicer to remove or adjust this.
Maybe custom g-code so 100 extrusion rate first layer rest on the default 95 or something.
Or reveal where I can adjust this setting, maybe it is somesort of elafant feet correction. But it ruins my prints.
This topic was modified 5 years temu by Pim B
Opublikowany : 08/12/2020 9:14 pm
RE: Underextruding on first layer while rest of the layers are perfect
Live Z lower should sort the first layer!
Which Printer?
Joan
Opublikowany : 08/12/2020 11:25 pm
SDrako
(@sdrako)
underextrusion could be related to several things, on a first layer a few things come to mind:
1 - first layer height - I know, I know, but worth checking
2- check the g-code for anything unsual - I usually star here
3 - extruder tension - my most frequent culprint, the extruder needs more tension in the screw so it does not skip, also could need calibration on the stepper voltage
4 - check alignments - it happens, for some reason the nozzle is not alligned in one axis (not perfectly vertical)
Opublikowany : 08/12/2020 11:51 pm
Pim B
(@pim-b)
@joantabb
I did this with my second print with the updated profiles. I lowered it from -1.167 to -1.223, while nothing had changed to my printer.
My printer is a mk3s, with a bondtech extruder upgrade
Opublikowany : 09/12/2020 6:53 am
Pim B
(@pim-b)
@sdrako
1 - after the profile updates the first print was a terrible first layer, so with the second one I lowered it to compensate -1.167 to -1.223
2 - I don't understand the g-code very well, but I check the layers in the slicer voor weird artifacts, they sometimes happen.
3 - was my first on my mind, checked it but no improvement. (Note if it comes loose while printing, put a little bit of loctite on the trhead of the screw, solved it for me).
4 - checked it now, seems completly vertical.
While typing this, I can also check and start an older g-code file and see what happens, I'll try that today.
Opublikowany : 09/12/2020 7:04 am
Pim B
(@pim-b)
@sdrako
@joantabb
Tried an older g-code, had to raise my z off set to -1.170 to get a nice first layer. So defintly something to do with the updated profiles.
Guess I just uninstall prusaslicer and reinstall and hopefully that fixes something. Some small optimisations I had for some of my filaments are easily recreated.
Opublikowany : 11/12/2020 12:15 am
