Unattached Strings On Disk Above Supports
Ken
 Ken
(@ken-7)
I'm using an i3-MK3S with Hatchbox PETG.  My Slicer settings are:
0.20 mm Quality, Generic PETG, Original Prusa i3 MK3S
Support on Build Plate Only
My Print is a cylinder with a 3 mm thick cross section part way up from the bottom.  I tried to attach the STL file but this forum doesn't allow that.
When the cross section starts to print on top of the support, I get loose strings for the first layer or two.
Any suggestions would be appreciated.
Ken
Napsal : 24/11/2020 7:04 pm
Ken
 Ken
(@ken-7)
RE: Unattached Strings On Disk Above Supports
Here's what it looks like from the bottom.
Napsal : 24/11/2020 8:45 pm
The forum doesnt allow many file types.  You need to zip them up into an archive.
However don't post the stl file.  It is much better to save your project with the part in slicer (File>Save as).  This will save a *.3mf file.  Zip that up and attach it to a post here.  The 3mf will contain your model and all of the settings you are using, print, filament and printer.  Its a MUCH better way to debug issues as you don't need to post any of the hundreds of settings that could be causing issues.  We can slice and look at he preview etc and try and spot potential issues.
Also a picture showing these loose strings would go a long way to actually understanding what your exact problem is.
Napsal : 24/11/2020 9:17 pm
Ken
 Ken
(@ken-7)
I'm attaching the ZIP file here.Milk-6
I can't get a meaningful photo with white strands on a white background.
The problem is that the strands being laid down are not sticking to the strands next to them.
Thanks for the info about the ZIP file.
Ken
Napsal : 24/11/2020 10:21 pm
Ok, I have I think a pretty good guess as to your issue.  That area inside is basically all bridges, and while the mk3 is ok at bridges, it isnt the best.  With bridges that length I think it cant do them properly.  So they are sagging down.
The setting you have enabled (as its the default) is under Print Settings>Support Material>Dont Support Bridges.  Untick it and it will add support under them too as well as just the perimeter.  Also the default contact z distance of 0.1 is too close.  Its a crappy default and will make removing the supports much more difficult, especially with petg.  0.2 or even 0.25 is better.
The underside still wont be pretty as Slicer (all the versions, PS, SuSie, Slic3r) don't do undersides of bridges well compared to some other slicers.  Its one area that could use a lot of improvement.  There's other threads about that already though so go do a bit of reading if you want to find out more.
I've attached a modified project with the changes I'd make (I also increased support x/y separation a bit, spaced them apart more and increased interface layers from 2 to 4) which are pretty much my normal support settings.  Give that a go.
Attachment removed
Napsal : 24/11/2020 11:33 pm
Ken
 Ken
(@ken-7)
Hi Neo,  I really appreciate your help.  The printer is running now, and I'll know in 8 hours if it worked.
Prior to Prusa Slicer, I used Cura which had a "Concentric" support pattern.  This seemed to work best with cylindrical projects.  I wish Slicer had this option.
Ken
Napsal : 25/11/2020 4:16 pm
Sorry missed your last reply.  The support itself doesn't have concentric but the support interface drop down contains many more options including concentric iirc.
Napsal : 28/11/2020 9:37 am
Ken
 Ken
(@ken-7)
Hi Neo,
I ran the print with your settings and it reduced the strings by about 75%, But they were still there.
I was thinking about maybe increasing the print head temperature just as it was getting to the transition point in an effort to get the filaments to stick together better.
Do you think that this might help?
Ken
Napsal : 28/11/2020 3:07 pm
When you say strings are they hanging down, like dangling or are they just not firmly fused together so the surface isn’t smooth ?  The first option would be some issue but the second option I’m afraid is pretty normal for slicer bridges. There’s a few threads around here about it and the general conclusion is a different slicer should be used if it’s vital.
There’s a few things you can try to help but without a zipped up 3mf project file to have a look at and experiment with a few settings it’s hard to say which of them will work.
Napsal : 28/11/2020 3:47 pm
Ken
 Ken
(@ken-7)
The strings don't sag, they are just not attached to the strings on either side or the ones above.  I'm going to make a smaller test with only a few mm of supports and experiment with different settings.
Ken
Napsal : 28/11/2020 3:55 pm
Ken
 Ken
(@ken-7)
Posted by: @neophyl
Where do I find the "Support Interface Drop-down"?
Napsal : 28/11/2020 4:20 pm
Sorry Ken.  I use Super Slicer (SuSie) a lot.  Which is built on and takes a lot from Prusa Slicer.  Its just got way more settings and options, many of which have been requested for ages in PS but aren't there.  As such the drop down I mentioned is not in PS.  I'm just so used to having it and the programs are the same basically that I forget sometimes which ones are missing from PS (of which there are so so many).
At the moment you can even use the new monotonic or an ironed support interface.
There's an earlier thread (one of several) https://forum.prusa3d.com/forum/prusaslicer/bridging-infill-settings/ where I posted some pictures of my experiments with bridges in SuSie.
Napsal : 28/11/2020 6:07 pm
Ken
 Ken
(@ken-7)
Hi Neo, I have been experimenting for days and here is where I'm at (using the slicer with the Concentric option).
MAJOR PROBLEM
First layer on top of support does not properly adhere to the layer on top of it.
SECONDARY PROBLEM
Strands on first layer sometimes separate from adjacent strands.
OBSERVATION
The first layer prints at a much lower speed than subsequent layers.
THEORY
The first layer is not hot enough to stick properly because of cooler air rising up through the supports and the slow speed allowing the material to cool down too much between layers.
CONCLUSION
Other than manually altering things like temperature, speed, fan, and flow rate at the transition point, I can't think of what I can do to fix this.
Do you have any suggestions on things I can try?
Ken
Napsal : 30/11/2020 7:52 pm
