Unable to remove or otherwise hide system presets
OnlyIfUsayPlz
(@onlyifusayplz)
Mitglied
I have no desire to use any of these presets (same with filament) and I can't seem to find a way to get rid of them or hide them. Is there a file somewhere I have to edit or delete? Thanks in advance.
Veröffentlicht : 25/05/2025 9:13 pm
RE: Unable to remove or otherwise hide system presets
Don't believe there is. The whole profile management approach is very suboptimal, and many improvements have been suggested on Github but Prusa doesn't seem to be interested in rethinking their approach in that area.
Veröffentlicht : 26/05/2025 1:27 pm
OnlyIfUsayPlz
(@onlyifusayplz)
Mitglied
None whatsoever? Seems like an oversight. There's gotta be a file stored somewhere, no?
Veröffentlicht : 26/05/2025 5:33 pm
Well you can uninstall the printer and then they go away. But as Foxrun says there's not much in the way of options. You can suppress default presets and template presets but not the system ones. Presumably if you install the printer you want the print profiles too.
While you can untick filaments during the installation wizard the print ones are bundled.
Even if you go in and edit the nuts and bolts prusa ini files to edit things (which risks breaking other things due to the dependency mechanism used) then the next time there's an update of the profiles from Prusa the files will be updated and you are back to square one again.
Veröffentlicht : 26/05/2025 6:06 pm
Delici0us _
(@delici0us-_)
Mitglied
The option General: Suppress "Template " filament presets [277] is available to hide them. I am on PrusaSlicer-2.9.4.
Veröffentlicht : 21/02/2026 1:02 pm
