Unable to edit numbers or stuff in text boxes reliably
Fallon
(@fallon)
I'm trying to emboss a logo from a SVG onto a model. I can emboss the logo fine, but when I go to edit the details of the SVG, particularly the Depth field, the default + & - buttons are to granular & default to 1mm steps where I need .2 or .4mm. On the first color in the logo I was able to select the numbers & use the keyboard to edit them. On the 2nd color in the logo whenever you try to modify the values it does not type over the existing numbers & hitting back space or delete just deletes the object out of the platter.
I've ran into similar issues with editing other attribute numbers previously. Selecting numbers & editing them frequently seems to put input into doing things in the slicer & not into editing the text box you have highlighted. It doesn't seem to be consistent on where the mouse cursor is, what text is or is not highlighted. I had similar results trying to use the add part > text function somewhat recently as well.
Clicking on the depth text to highlight it, or clicking again to put the cursor in the text field has no reliable relationship to editing text in that text box. I just set the N7 text .svg to .4mm deep fine, then trying to set the wedge .svg to the same keeps deleting the object. I gave up, saved the project, closed prusaslicer. Reopened the project & was promptly able to edit the depth to .4mm by just editing the dept text field.
Does this need to be a bug report? Am I missing something?
Opublikowany : 08/03/2025 5:10 am
