Un install PrusaSlicer
raymate
(@raymate)
Im new to Prusa ive just ordered the Mini+ so I installed PrusaSlicer onto my Mac just to play around with it and see how it work so im ready for my printer when it arrived around Feb.... I hope.
My question is how can I un install it or reset it back to defaults so I can start fresh when my printer arrives. Also as I tried to make it work with my current none Pusa printer, now the Slicer is all a bit messed up so I need to reset it somehow anyway, i figured un installing it should do the trick
Like I say im on Mac
Prusa Mini+ (Ordered Dec 19,2020 - Arrived Feb 21,2021) stated clicking Mar 2nd / MP Select Mini V2
Opublikowany : 31/12/2020 11:51 pm
RE: Un install PrusaSlicer
Hi Raymate,
the latest full release of Prusa Slicer is 2.2.0
2.3.0 Beta 2 is available but probably not a good idea for a new user,
If you already have 2.2.0,   Use the Configuration>Configuration wizard, to load the Prusa configuration for your new printer ( there are three Profiles for the Mini+  the standard profile uses a 0.4mm nozzle, then there is a 0.25mm nozzle and a 0.6mm nozzle version as well, and choose a selection of filament profiles
If you decide to buy additional nozzles it would be a good idea to limit yourself to 0.4, 0.25 and 0.6mm so that you can use the pre configured profiles, until you get a bit more experienced.
Opublikowany : 01/01/2021 1:26 am
1 ludzie polubili
Area51
(@area51)
I you want to reset and delete the current configuration in PrusaSlicer, go to Help->Show Configuration Folder and delete the files there.
I you want a safety copy of the configuration before deletion, then use File->Export->Export Config Bundle with Physical Printers to save a copy of the current configuration that can be imported into PS again.
Opublikowany : 01/01/2021 2:17 am
1 ludzie polubili
raymate
(@raymate)
@area51 @joantabb
Thank you for the replies it looks like I don't need to uninstall, after deleting that folder I got the setup wizard again and all is well
Thanks
Opublikowany : 01/01/2021 2:26 am
