Turn heated bed off?
BenHark
(@benhark)
Is it possible the turn the bed off after a certain height (layers printed).
It seems pointless to have it off all the time wasting all that energy.
Opublikowany : 09/08/2022 1:08 pm
RE: Turn heated bed off?
Pei loses adhesion at low temperatures
You may get premature part release
Opublikowany : 09/08/2022 6:58 pm
Or use custom before layer change gcode but as Joan said, probably not a great idea.
Opublikowany : 10/08/2022 3:41 pm
Robin
(@robin)
Yes. Right click the "+" button in the layer slider and use "add custom G-code" to add: "M140 S0" to turn of bed heating.
Depending on your material and type of plate you will get the object released from the plate, as Joan pointed out.
Opublikowany : 11/08/2022 10:47 am
BenHark
(@benhark)
Thanks, I didn't know you could do that. I will give it a try and see if it works and doesn't release. I don't think it will...
Opublikowany : 11/08/2022 3:17 pm
Bizkit83
(@bizkit83)
has someone this custom gcode?
I wanna add this to my printer gcode.
Greetz
Opublikowany : 04/11/2022 7:59 am
Robin
(@robin)
Posted by: @bizkit83
Greetz
You mean "M140 S0"?
Opublikowany : 04/11/2022 10:40 am
Bizkit83
(@bizkit83)
No, i mean more like this:
if(layer_z == 15) M140 S0 endif
so if my printjob is in layer 15 the bed will turn off
Opublikowany : 04/11/2022 12:01 pm
