Turn heated bed off?
Is it possible the turn the bed off after a certain height (layers printed).
It seems pointless to have it off all the time wasting all that energy.
RE: Turn heated bed off?
Pei loses adhesion at low temperatures
You may get premature part release
Or use custom before layer change gcode but as Joan said, probably not a great idea.
Yes. Right click the "+" button in the layer slider and use "add custom G-code" to add: "M140 S0" to turn of bed heating.
Depending on your material and type of plate you will get the object released from the plate, as Joan pointed out.
Thanks, I didn't know you could do that. I will give it a try and see if it works and doesn't release. I don't think it will...
has someone this custom gcode?
I wanna add this to my printer gcode.
Greetz
Greetz
You mean "M140 S0"?
No, i mean more like this:
if(layer_z == 15) M140 S0 endif
so if my printjob is in layer 15 the bed will turn off
