Trying to improve Top Solid Infill results on a print
rud
 rud
(@rud)
Hello community!
I am trying to print the Low Poly Fox ( https://www.thingiverse.com/thing:937740 ) on an I3 MK3s, using PrusaSlicer and the "0.20mm Quality MK3" profile.
When doing so, I notice that the top portion of the left ear and left foot appears to have a few of "red-steps-like-lines" (which I assume are Top Solid Infills in the picture).
Is there any PrusaSlicer setting I could tweak in order to get a better print result for these areas of the print ?
Thank you !
Opublikowany : 03/12/2019 1:55 pm
RE: Trying to improve Top Solid Infill results on a print
Hi Rudolph,
You could try reducing the layer height to make the steps less obvious
Opublikowany : 04/12/2019 1:20 am
