Trying to change only one axis in "Object Manipulation" box....
[Solved] Trying to change only one axis in "Object Manipulation" box....
montejw360
(@montejw360)
Is there a way to change one axis by itself in the "Object Manipulation" box on the right side of the screen. I've tried with shift, ctrl, alt, shift/crtl, etc.
I can drag the object handles and do one axis at a time but it's hard to hit a specific value and the handle shows %, I'd like to hit a specific mm height.
thanks.
Best Answer by Neophyl:
Yes, click on the padlock symbol next to the manipulation fields to unlock it. Then you can change just one axis.
https://forum.prusa3d.com/forum/prusaslicer/change-size-in-one-dimension-only/ For a previous post here with pictures.
Napsal : 12/04/2025 3:42 am
Napsal : 12/04/2025 6:49 am
montejw360
(@montejw360)
RE: Trying to change only one axis in "Object Manipulation" box....
Posted by: @neophyl
thank you.
Napsal : 12/04/2025 3:25 pm
