Trying Prusaslicer, can't find a specific internal solid infil setting
So i'm used to Orcaslicer. In order to determine i brittle petg-cf print i'm having (even after drying it for 8h at 60C) i'm attempting to use prusaslicer for the first time for real. Now to have a good looking result for that specific model i needed to disable "detect narrow solid infil" in orcaslicer but i can't locate a similar setting in PS.
Reason being that, right now, due to the model design (SICCO BOX, filament carrier left/right) around layer 40 in PS it switches the solid infil from monotonic to concentric. This in orcaslicer yielded improper adhesion to the infil and edges curling up. Disabling that setting maintained monotonic through the print and had the desired effect and resulted in a beautiful finish print (although brittle)
I need that setting disabled in prusaslicer too.
Also what are y'alls cooling settings for petg-cf (sunlu)
RE: Trying Prusaslicer, can't find a specific internal solid infil setting
That setting doesn't exist in PS. https://github.com/prusa3d/PrusaSlicer/issues/10573
This still wasn't added after 2+ years? Then I can't use PS for this model
