Tree support
Alex
 Alex
(@alex-15)
Tree support
Hello everyone, Prusa Slicer is an excellent slicer, after trying it with others there is no desire to return. The only thing I would like is tree-like supports like in Cura, thanks to them you can achieve very high print quality without affecting the model itself with "snot". Thanks.
Posted : 17/03/2022 3:17 am
You can do it with a bit of a workaround.
Tree supports are enabled for SLA printers only - eventually they will be available generally but I presume there are some details to finalise...
So:  Enable an SLA printer.  Slice with supports, save the result as STL *including supports*, close.  Reopen and enable your printer of choice, import the STL which now has supports attached, slice again and now you have gcode with tree support...
Posted : 17/03/2022 1:22 pm
mgilles
(@mgilles)
RE: Tree support
I agree it reduces the waste so much. For me it's the one reason to use Cura instead of PrusaSlicer
Posted : 17/03/2022 3:44 pm
bapski
(@bapski)
RE: Tree support
Posted by: @diem
i tried this workaround, unfortunately it limits the size of the model to the size of the SLA bed which is way smaller than the Mk3s bed.
MY MODELS AT PRINTABLES
Posted : 17/03/2022 5:46 pm
Modify the sla printer bed size.  and printer height.  Its all configurable in your profile settings.  Printer Settings>General.  Max Print Height I hope is obvious and the Set Bed shape button, which when clicked allows you to set x and y.
Then save the modified profile and slice.
Posted : 17/03/2022 8:31 pm
