Travel of a cilindrical object has a lot of jumps
Johan Vergeer
(@johan-vergeer)
I just started with PrusaSlicer and I'm trying to create a cilindrical object with three diffent diameters. I would think it would just create a circle on each layer, move up and create a new circle on the next layer. But looking at the paths and the preview slider the nozzle randomly jumps around on some of the layers.
How can I prevent these random jumps and just let the nozzle create a few circles on each layer?
I created a screen recording and an image which shows the nozzle path. Screen Recording 2022-12-02 at 21.05.06
This topic was modified 3 years temu by Johan Vergeer
Opublikowany : 02/12/2022 8:10 pm
RE: Travel of a cilindrical object has a lot of jumps
You could try avoid crossing perimeters
You could save your project as a project file, and then zip compress the file, and load the compressed file here for us to play with.
Regards Joan
Opublikowany : 02/12/2022 9:52 pm
Johan Vergeer
(@johan-vergeer)
Hi Joan,
Thanks for your response. I've set avoid crossing perimeters, which does solve that issue. The time it takes to print wasn't really affected by it, though. I have uploaded the file here.
Tussenstuk v2.3mf
Opublikowany : 03/12/2022 12:00 pm
