Transfer object settings / color changes from one model to another
[Solved] Transfer object settings / color changes from one model to another
vmLOGIC
(@vmlogic)
I am in the process of printing large models, each of which is divided into 16 different individual parts.
For the first part I have defined some object settings (right in the slicer: Layers, Ranges, Infill). Also the color changes.
I can't find a way in the slicer to transfer the object settings and color changes of the first part to further parts.
Is that not possible in the slicer or have I just not found the function yet?
I would be very grateful for any hints or ideas.
Best Answer by R&D:
Read this link all the way through.
https://forum.prusa3d.com/forum/prusaslicer/copying-modifier-setttings/
I will add to that, Objects can have propertied that parts and modifiers can't, however you can copy properties from one object to another, I don't know what kind of color changes you have set up, but I will also add that its possible to "Replace with STL" this allows you to replace one model with another, depending on how you have set your project up certain properties may not transfer when doing so. (e.g. Paint on supports, Seam painting and Multi-Material paint).
This may help you.
Posted : 04/02/2023 10:08 am
R&D
 R&D
(@rd)
RE: Transfer object settings / color changes from one model to another
This may help you.
Posted : 04/02/2023 10:29 am
vmLOGIC
(@vmlogic)
Thank you for the link. It took me a moment to understand the procedure, but it worked in the end. The color changes are not copied, but I have only two of them in each part. I can add those by hand as well.
That you can transfer such settings with stl, I have already read elsewhere. However, I did not succeed.
Posted : 04/02/2023 11:02 am
vmLOGIC
(@vmlogic)
I correct my previous statement: the color changes are also copied.
Posted : 04/02/2023 11:37 am
