Total weight including spool placeholder name
MonoTovarisj
(@monotovarisj)
Any way to add the totalweight including the spool weight in the filename?
Weight of filament is {total_weight} and spool weight is {filament_spool_weight}
However I can't figure out the placeholder name for them added up. Is there a way I can add them up in the output filename format?
Posted : 11/06/2021 11:52 am
RE: Total weight including spool placeholder name
I’d have to try the specifics (not at a pc at the moment) but something like _total weight ({total_weight}+{filament_spool_weight})g_ would I think add a into the output “_total weight xxxg” with the xxx being the result of adding the 2 together.
Posted : 11/06/2021 1:49 pm
MonoTovarisj
(@monotovarisj)
Got this:
Failed processing of the output_filename_format template.
Parsing error at line 1: Referencing a vector variable when scalar is expected
{input_filename_base}_({total_weight}+{filament_spool_weight})gr_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}.gcode
Posted : 11/06/2021 1:56 pm
MonoTovarisj
(@monotovarisj)
Seems actually like filament_spool_weight can't even be used alone 🙁
{input_filename_base}_{filament_spool_weight}gr_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}.gcode
Posted : 11/06/2021 1:59 pm
MonoTovarisj
(@monotovarisj)
And this
{input_filename_base}_({total_weight}+201)gr_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}.gcode
results in this:
Filename_(15.0353+201)gr_0.2mm_PETG_MINI_2h15m.gcode
So doesn't seem like it can parse +
Posted : 11/06/2021 2:02 pm
My normal output format is "{input_filename_base}_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}_{int(total_weight)+1}g.gcode"
So transposing that I can use
"{input_filename_base}_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}_{(total_weight)+(filament_spool_weight[0])}g.gcode"
That gives me a proper weight of the filament plus whatever is in the spool weight field of the filament.  As its filament you have to use [0] after it as its an array, even with only one filament selected there is more internally for when its being used bu a MMU with multiple filaments available.
Personally I don't like the many decimal points but you can trim them off by using the int option like my normal one and you can do the following - for more decimals use "...{int((total_weight*10.0))/(10.0)}g..." or replace the "10.0" with any order of magnitude you like.
And yes, the amount of brackets look redundant, but they are important.  You can adapt that to do the rounding however you want.
Posted : 11/06/2021 2:29 pm
