Files > Save Project as
Veröffentlicht : 14/05/2025 10:13 am
RE: top solid infill all part long ?!?
As Diem says without your project file its hard to say. However the most likely cause is a setting called Solid infill threshold area. Its a red/expert level setting so make sure you are in expert mode.
Located in Print Settings>Infill>Advanced. Some older profiles have a value of 70mm2 in there but newer ones have 0. Basically once an area goes below the mm squared value configured in there it uses solid infill rather than sparse infill. I'd be checking that first.
Veröffentlicht : 14/05/2025 12:06 pm
Thanks Neophyl Its resolve the trouble !!
Veröffentlicht : 15/05/2025 12:19 am
