top and bottom layers missing
stu28
(@stu28)
Utenti
hi, I have imported some ready made files into Prusaslicer and upon slicing the top and bottom layers are missing. The printer just starts printing the infill. The same file is ok in other slicers and I don't think that I have changed any settings. Any help would be appreciated.
Postato : 14/03/2024 11:48 am
RE: top and bottom layers missing
There's zero to work with here. Everything is going to be wild guesses without more information. If you upload your project as a 3mf file, you're likely to get better advice grounded in data. A 3mf file contains your STL but most importantly also ALL your settings.
In PrusaSlicer, go to File/Save project as, to create the 3mf file. Zip-compress it to turn it into a .zip file (right-click Compress on Mac and Win11, right-click Send to/Compress on Win 10). Attach the zipped file a post on this forum using Attach file below the text edit box. It has to be a zip file, or the forum software will silently reject it.
Postato : 14/03/2024 1:46 pm
1 persone hanno apprezzato
